direct fax 1090
pitoaudiovisual
Copper - Posts: 388
Posted: December 20, 2007 at 11:24 AM / IP Logged
Can someone please tell me what Direct Fax #1090 is???  Thank You!
Confidence is the key to any project!!
Twelvoltz
Platinum - Posts: 2,384
Posted: December 20, 2007 at 12:34 PM / IP Logged
1090 tells you to cut the factory wait to start wire and insert a diode with the cathode (striped) side facing away from the light (towards the pcm) and connect your wait to start input on the pcm side of the wire.
Friday, January 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
