need wiring diagram for 1993 nissan
mikeknerr
Member - Posts: 22
Posted: February 24, 2003 at 7:00 PM / IP Logged
I need a wiring diagram for a 1993 nissan pickup.  I am installing an alarm system.
Bnluis
Silver - Posts: 578
Posted: February 24, 2003 at 7:21 PM / IP Logged
1993 nissan pickup.
|              12V|WHITE/ black         |+  |ignition harness            |
|          STARTER|BLACK / YELLOW        |+  |ignition harness            |
|   SECOND STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|        ACCESSORY|BLACK/ blue          |+  |ignition harness            |
|       POWER LOCK|BLACK / YELLOW        |-  |driver's kick panel         |
|     POWER UNLOCK|BLACK/ red           |-  |same                        |
| PARKING LIGHTS +|pink/blue           |   |steering column             |
|       HEADLIGHTS|RED / grn,RED / blk(L,R)|+  |steering column             |
|     DOOR TRIGGER|RED / black *1        |-  |left A pillar               |
|  TRUNK/HATCH PIN|                    |   |                            |
|       TACHOMETER|white               |   |lg. conn. by dr. kick       |
|       BRAKE WIRE|GREEN/ YELLOW        |+  |at brake pedal switch       |
|     HORN TRIGGER|lt. GREEN/ black     |-  |steering column             |
|           WIPERS|blue/red            |-  |steering column             |
|  LF WINDOW UP/DN|blu/blk - blu/red   |A  |either kick panel *2        |
|  RF WINDOW UP/DN|blu/yel - blu/wht   |A  |either kick panel           |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
Notes:
*1 some models do not have a factory pin switch installed on the passenger side.  *2 the drivers window wires run out of the drivers door to the power window amp in the passenger kick panel.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
mikeknerr
Member - Posts: 22
Posted: February 24, 2003 at 7:55 PM / IP Logged
Thanks a lot for the info.
