remote starter 05 silverado
bigdig
Member - Posts: 8
Posted: December 23, 2007 at 11:52 AM / IP Logged
05 silverado manual transmission have the ultrastart & security u2271m . i got the security part to work and i can even shut the truck off with the remote but i cant get it to start with remote. when you hit the start button the manual says boxs will click 4 times then start i get the 4 clicks but nothing after that.
i have a anti-grind/starter kill output -250ma can anyone tell me where that wire hooks to
thanks for any help
Moderator - Posts: 12,488
Posted: December 23, 2007 at 6:31 PM / IP Logged
What bypass module did you use ? Also, make sure that you have the starter and motor side of the starter wire on the proper side of the relay.
bigdig
Member - Posts: 8
Posted: December 23, 2007 at 8:23 PM / IP Logged
i used the pljx gm passlock1&2 vats & ion self learning resistor interface
bigdig
Member - Posts: 8
Posted: December 24, 2007 at 11:52 AM / IP Logged
i have check the remote starter im not getting any power out of starter out wire.thanks for any help
Wednesday, January 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
