2001 taurus dome light
cmk0808ny
Copper - Posts: 203
Posted: December 23, 2007 at 9:14 PM / IP Logged
does anybodyn know if there is a neg domelight trigger in a 2001 taurus- such as at the headlight switch?
Twelvoltz
Platinum - Posts: 2,384
Posted: December 23, 2007 at 9:21 PM / IP Logged
If you are looking for an alarm trigger you can use the BLACK/ orange at the GEM. This is the wire that turns on the door ajar indicator in the dash. You would need to diode isolate it from the instrument cluster.
cmk0808ny
Copper - Posts: 203
Posted: December 23, 2007 at 9:27 PM / IP Logged
i want to use it for dome supervision on a viper 160xvl
cmk0808ny
Copper - Posts: 203
also car is a station wagon.
Twelvoltz
Posted: December 23, 2007 at 9:40 PM / IP Logged
Just take your dome light out from the 160 and tap it into the yellow/black at the 26 pin plug of the GEM. This is the driver's door trigger and is a low current trigger. Verify the wire with your DMM prior to tapping into it. Keep in mind that your door ajar indicator will illuminate the entire time your dome light output is active but it eliminates the need for an additional relay.
