remote start using factory keyless
bj202
Posted: December 24, 2007 at 12:02 AM / IP Logged
I have installed a remote start used a intellakit. The starter works, but I can not find a way to activate the starter with the factory keyless. Can any one help. The car is 2005 Honda Element. I found the WHITE/ blue wire at the drivers kick panel, but it has a ground all the time. Thanks, B.J.
Platinum - Posts: 13,725
Posted: December 24, 2007 at 4:19 AM / IP Logged
I am not familiar with that particular module, but the ones we install have a selection for  , 2, or 3 pulses to activate.  We use 3 pulses and connect it to the trigger of the Lock Relay.  Lock, Lock Lock will start the vehicle.
Twelvoltz
Platinum - Posts: 2,384
Posted: December 24, 2007 at 5:04 AM / IP Logged
Problem with doing an add on with the Honda is the factory remotes do not operate after the vehicle is running. This means that once you remote start the vehicle you will have to unlock it with the key.
The wire you are looking for that provides a positive pulse when locking is yellow/black in the driver's kick panel. This is the lock leg of the actuator in the driver's door, it rests at ground and goes to positive when locking.
bj202
Posted: December 24, 2007 at 9:01 AM / IP Logged
Thanks I was doing it late and not paying attention, a relay and I am done. I set the run time to 10 min the car is mostly warm by then. She should be able to use the remote by then.
bj202
Posted: December 24, 2007 at 11:29 AM / IP Logged
I hooked up the relay on the yellow black wire in the kick panel, it started once then nothing. When every thing is hooked up lock the doors the dash lights blink twice or three times so it kills the sense and will not start. The starter is a Omega Mars-10 add on starter.
