03 avalanche remote start problem
swatpilot
Member - Posts: 8
Posted: December 30, 2007 at 9:26 PM / IP Logged
I installed a RS on a 03 Avalanche but have one problem.  When the RS is activatied, it start the car fine but the factory alarm goes off.  I connected the factory OEM alarm disarm wire to the lt green wire on the BCM purple plug.  All the information I have shows this to be the (-) trigger OEM disarm wire.  Any thoughts?
Twelvoltz
Platinum - Posts: 2,384
Posted: December 30, 2007 at 10:00 PM / IP Logged
What bypass module did you use? What RS system did you install?
The analog factory alarm disarm wire is a light green wire negative trigger, but it is at the driver door module in the door not available at the BCM.
swatpilot
Member - Posts: 8
Posted: December 30, 2007 at 11:03 PM / IP Logged
I did it for a friend, he got a Mars 11 RS and omega bypass, as for the light green wire at the window module, is that the module at the door switch?  The sheet I got said both at the window mod. and the BCM.
Chris Luongo
Platinum - Posts: 3,746
Posted: December 31, 2007 at 10:42 AM / IP Logged
You did test the green wire at the BCM, and not just blindly connect to it, right?
The correct disarm wire is only available inside the door from 2003-up.
If you use a databus module to control the doorlocks from the aftermarket remote, that'll take care of the disarm too.
Also, these trucks only make a very brief horn honk when remote starting; I'm surprised your friend is bothered by it.
chriswallace187
Gold - Posts: 1,661
Posted: December 31, 2007 at 1:23 PM / IP Logged
The driver's door module and window module are one and the same...the big stupid piece with locks/windows/mirror switches.
To my knowledge on all '03-06 GM full-size trucks/SUVs the disarm wire is only at the driver's door module - BCMs are different from the '99-'02 models, which didn't use a driver's door module.
Testing it - connect your meter's red lead to 12v+, black lead to the green wire. When you turn the key in the door to unlock, meter should read +12 volts.
C Renner's Auto Electronix
swatpilot
Member - Posts: 8
Posted: December 31, 2007 at 5:11 PM / IP Logged
Thanks Ill give it a try
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
