03' hummer H2
mxxmikexx
Silver - Posts: 796
Posted: February 25, 2003 at 2:30 PM / IP Logged
does anyone have a wire diagram for the new H2 Hummer?
and also... i have a customer who has a limo service, and he keeps his vehicles parked at a yard a few miles from his house. does anyone offer a pager for an alarm that will work up to a 5 mile range? he has been broken into repeatedly and his main goal now is to catch the people doing this, so he wants a pager so the next time he gets broken into, he can call the cops and hopefully catch them in the act, but all the systems that ive seen dont work that far. any ideas?
the12volt
Administrator - Posts: 3,959
Posted: February 25, 2003 at 2:43 PM / IP Logged
Best bet would be to secure the yard with a fence and alarm system that automatically notifies the police or find a better location to store his vehicles. We plug some of our vehicles left outside directly into the alarm system in the building. If any of the vehicle alarms are triggered, they trigger the alarm in the building by opening a closed loop. The cables going from the vehicles to the building look just like 120V AC extension cords and if unplugged will also cause the building alarm to trigger. Typically a thief will not attempt to cut what appears to be a live extension cord.
BTW, sorry, no diagram for the new H2.
03' hummer H2 -- posted image. the12volt • Support the12volt.com
Platinum - Posts: 12,488
Posted: February 25, 2003 at 2:47 PM / IP Logged
|              12V|red & RED / white     |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|white               |-  |switch on right rear panel  |
|     POWER UNLOCK|lt. blue            |-  |switch on right rear panel  |
|       LOCK MOTOR|gray                |   |driver door module in door  |
|     UNLOCK MOTOR|tan                 |   |driver door module in door  |
|    DISARM DEFEAT|tan                 |   |driver rear door harness    |
| PARKING LIGHTS +|brown               |   |driver kick panel           |
| PARKING LIGHTS -|gray/black          |   |headlight switch            |
|       HEADLIGHTS|pink or white       |-  |headlight switch            |
|     DOOR TRIGGER|*1                  |-  |*1                          |
| DOME SUPERVISION|comes on with disarm|   |                            |
|  TRUNK/HATCH PIN|pink/black          |-  |harness to BCM *2           |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|lt. green           |-  |driver door module in door  |
|       TACHOMETER|NOT pink            |   |any fuel injector           |
|      SPEED SENSE|GREEN / WHITE         |   |pin 50, grn plug @ PCM *3   |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black or blk/yel    |-  |column or gray plug @ BCM *2|
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|blue - brown        |A  |LF window switch in door    |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |RF window switch in door    |
|  LR WINDOW UP/DN|blue - brown        |A  |LR window switch in door    |
|  RR WINDOW UP/DN|blue - brown        |A  |RR window switch in door    |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with.  *1 The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black and the RR is lt. GREEN/ black, they are in a harness in front of the fusebox leading to the BCM rear plug. Use all four wires and diode isolate each.  *2 The BCM (Body Control Module) is located behind the headlight switch.  *3 The PCM (Powertrain Control Module) is under the hood on the driver side.
the12volt
Posted: February 25, 2003 at 3:39 PM / IP Logged
There ya go....;)
camino
Copper - Posts: 54
Posted: February 25, 2003 at 8:29 PM / IP Logged
some times theres special jobs,for that i say theres a special way to do it,one time a costumer tell me,you think is posible to record a video inside and outside of my car when the alarm has been triggered?i said is posible,but not chip,he says just do it,and we did it.we install a system of two cam's one from the inside and another just in front of the car,that way he can see inside car and catch the posible thief.well i guess all of us have to do special work's like this.once in a while.
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
