how to trigger strobe with alarm/switch
kickercivic1
Member - Posts: 34
Posted: January 02, 2008 at 8:22 PM / IP Logged
I just bought whelen strobes to go in my car. I have viper 5900 alarm installed in my car. When my alarm goes off, i want the strobe to also start flashing, but my problem is i also want to have switch that i can control the strobe on/ off inside the car. So they come on with alarm or when i am at the show i just flip a switch.
KPierson
Platinum - Posts: 3,527
Posted: January 02, 2008 at 9:15 PM / IP Logged
Depending on where you put them, and a few other factors, you may be able to power them right off the siren output of the alarm.  However, keep in mind that they strobe may or may not flash when you arm and disarm the system.  If the caps in the strobe can be charged in the short time that the siren is beeping it may be enough to flash once or twice.  If this acceptable, then that would be a good route to go.
If you want to add an external switch you will need to diode isolate your siren(s) from your strobelight(s).  Once they are diode isolated you can put a toggle switch between the diode and the strobe.
Kevin Pierson
kickercivic1
Member - Posts: 34
Posted: January 03, 2008 at 7:49 AM / IP Logged
So i have to have two diode.. I will draw it up later on post the diagram.
KPierson
Posted: January 03, 2008 at 8:28 AM / IP Logged
Yes, two seperate diodes would be needed.  Both would attach to the siren output, with the stripe facing away from the brain (towards the devices).
Kevin Pierson
kickercivic1
Member - Posts: 34
Posted: January 03, 2008 at 11:10 AM / IP Logged
those 90watt strobe pull 10-15 amps... How big of diode's would i need?
tedmond
Gold - Posts: 4,610
Posted: January 03, 2008 at 12:24 PM / IP Logged
use your siren ouput and wire it to an external relay.
85 - ground
86 - 12v siren wire
70 - high current 12v fused @ 20 amps
30 - to strobe light 12v
KPierson
Posted: January 03, 2008 at 12:38 PM / IP Logged
Use 1A diodes, but as tedmond says, you will need to use a relay.  Diode isolate the relay from the siren, just like you would have the strobe.  The relay will draw less then 1A, so the 1A diode will be plenty.
You can still put the switch in the same place and make it all work!
Kevin Pierson
kickercivic1
Member - Posts: 34
Posted: January 03, 2008 at 7:03 PM / IP Logged
85 - ground
86 - 12v siren wire
Where would the diode go?? also where would the switch go?
tedmond
Gold - Posts: 4,610
Posted: January 03, 2008 at 10:40 PM / IP Logged
From pin 30. place a diode on each end of the wire you want to connect to pin 30. With diodes cathode band facing away from relay. also, the switch will sit after the relay so you have the option to turn it on or off. im sure viper has the ground when armed wire. if so, you can use 2 relays to allow the strobes to ONLY work when the car is armed. if you wish to do so heres how.
Relay to control lights
85 - ground
86 - 12v siren wire
30 - to pin 70 of relay 2 and one to siren with a diode, cathode (white band) away from pin 30.
Relay to allow strobe flash on ONLY when armed (must wire 2 relays together)
85 - constant 12v
86 - ground when armed from alarm
70 - wire from Pin 30 of relay 1 with diode inline cathode away from relay 1
30 - to strobe light 12v in
KPierson
Posted: January 04, 2008 at 5:28 AM / IP Logged
^^^ Not a good idea.
Most automotive relays will draw around 150mA of current to keep them energized.
With a relay connected to the ground when armed wire the battery will be dead in 4-7 days of not driving the car.
You should NEVER have a relay constantly energized when the car is off.
Kevin Pierson
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
