verify cold cathode light relay diagram?
passions
Member - Posts: 7
Posted: January 04, 2008 at 12:40 PM / IP Logged
This is my diagram to have a cold cathode light turn on automatically when I open the trunk (trunk light coming on). I also have a SPST switch to disable the relay whenever I don't feel like having such a bright light.
I'm grabbing 12v power from the trunk light fuse with an Add-A-Circuit device. Once the trunk light turns on, the relay goes active. I also have a 3A fuse for the cold cathode, I'm not sure if that is really necessary though (trunk light has a 7.5A fuse already..)
verify cold cathode light relay diagram? -- posted image.
I'm pretty sure that everything is correct, but maybe I'm missing something.
Thanks!!
hotwaterwizard
Silver - Posts: 1,350
Posted: January 06, 2008 at 1:15 AM / IP Logged
Why is the switch Grounded on the right side terminal of the switch?
Why use a relay if the wire will handle the current.
The power source is the same as the original bulb.
If you use a relay it is suppose to switch large current from a different power source like the Battery.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
passions
Member - Posts: 7
Posted: January 06, 2008 at 2:05 AM / IP Logged
It's a lighted switch, the ground is for the lighted part.
Hmmm...I'm using a relay because even though the wire can handle the current, I would like both stock bulb and new cathode to light up. Then if I turn off the spst switch, only the stock bulb turns on.
I think the power source being the stock bulb might be bad though. I'll try working on it more.
Thanks!
passions
Member - Posts: 7
Posted: January 07, 2008 at 7:54 PM / IP Logged
Hey, you're absolutely right.
I don't need a relay! The cold cathode uses 12V @ 700mA, so I can just use a T-tap into the trunk light. Low enough amps. Mannnn...all this diagram for nothing! Heh.
Thanks.
hotwaterwizard
Posted: January 07, 2008 at 8:33 PM / IP Logged
Well you asked the right questions and got an easy answer. Better to draw a little picture than to wire it all up and find out all your wires were not needed.
verify cold cathode light relay diagram? -- posted image.LOL
The only dumb question is the one you didn't ask.
Stockton California
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
