dome supervision, 05 titan
big d z
Member - Posts: 33
Posted: January 08, 2008 at 2:54 PM / IP Logged
Does anyone know which wire at the BCM is the dome supervision wire for an 05 Titan? The wiring diagrams listed on this site has it as BLUE PIN 63, but there is no PIN 63 on the BCM.
Anyone know which PIN in the BCM of which PLUG is the correct wire or know how I can find the wire?
Thanks,
Brandon
KarTuneMan
Platinum - Posts: 7,056
Posted: January 08, 2008 at 7:04 PM / IP Logged
If you are attempting dome light supervision, use a door pin.
Just make sure the output from your unit is dedicated for dome supervision.
big d z
Member - Posts: 33
Posted: January 08, 2008 at 11:35 PM / IP Logged
KarTuneMan,
I'm not sure I understand whether or not my unit is dedicated for dome supervision. Can you elaborate on what this means? I have a Clifford Matrix 50.5x.
Right now, I've diode isolated 4 door pins to the alarm door trigger (-). For the drivers door pin, in order to turn of the auto headlights after a remote start shutdown, I have a relay hooked up as:
86 ---- constant 12v
85 ---- wire of 50.5X programmed to Re-Arm
87 ---- ground
87a --- green door trigger input of alarm
30 ---- (-) door trigger of car
So if I add this dome supervision wire to the door pin,will that affect how the above works??
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
