2007 Dodge Durango Alarm/Remote Start Wiring
Welcome Guest :)
caraudio904
Copper -
Posted: January 22, 2008 at 6:43 AM / IP Logged
| KEY | T-HARNESS | IMMOBILIZER |
| N/A | N/A | CHRYSLER's TRANSPONDER SYSTEM, Requires 791 Bypass Module and Extra Programmed Ignition Key |
| PART | COLOR | LOCATION | DIAGRAM |
| 12 VOLT CONSTANT | RED / ORANGE (+) | @ IGNITION SWITCH HARNESS | |
| STARTER | PINK/LIGHT BLUE (+) | @ IGNITION SWITCH HARNESS | |
| STARTER 2 | N/A | | |
| IGNITION 1 | PINK/LIGHT GREEN (+) | @ IGNITION SWITCH HARNESS | |
| IGNITION 2 | PINK (+) or BLACK (+) | @ IGNITION SWITCH HARNESS | |
| IGNITION 3 | N/A | | |
| ACCESSORY /HEATER BLOWER 1 | PURPLE (-) and PINK / YELLOW (+) See NOTE *1 | @ IGNITION HARNESS, See DIAGRAM | 14301_DURANGO_775 for NEGATIVE ACCESSORY.pdf |
| ACCESSORY /HEATER BLOWER 2 | PINK/PURPLE (+) | @ IGNITION SWITCH HARNESS | |
| KEYSENSE | N/A | | |
| PARKING LIGHTS ( - ) | PINK/RED (-) Thru a 1100 Ohm Resistor See NOTE *2 | @ HEADLIGHT SWITCH, See DIAGRAM | |
| PARKING LIGHTS ( + ) | PINK/RED (+) Left and WHITE/ ORANGE (+) Right, use both! See NOTE *3 | @ FUSE BOX, BLACK Plug, Pins 5 and 6, See DIAGRAM | 14301_DURANGO_DUAL PARKING LIGHT DIAGRAM.pdf |
| POWER LOCK | PURPLE / DARK GREEN (In the door an boot) ORANGE / Blue (In Car) This one was killing me found out the long way 1-Wire Door Locking System See NOTE *4 | See NOTE *4 | 24464_DURANGO_DODGE DURANGO II 1 WIRE JBS UNITS.pdf |
| POWER UNLOCK | Same wire | | 24464_DURANGO_DODGE DURANGO II 1 WIRE ALERT SHEBY UNITS.pdf |
| LOCK MOTOR WIRE | LIGHT GREEN (TYPE C) | @ DRIVERS KICK PANEL, in DOOR Harness | |
| DOOR TRIGGER | See NOTE *5 | See NOTE *5 and DIAGRAM | 14301_DURANGO_DURANGO DOOR PIN ISOLATION.pdf |
| DOMELIGHT SUPERVISION | YELLOW/ORANGE (+) | @ LARGE 74-Pin Plug near FUSEBOX | |
| TRUNK RELEASE | PURPLE / TAN (-) | in DRIVERS KICK PANEL, HARNESS to REAR of VEHICLE. | |
| SLIDING POWER DOOR | N/A | | |
| HORN | DARK GREEN/ PURPLE | @ HORN SWITCH | |
| TACH | NOT RED or BROWN / WHITE | @ Any IGNITION COIL or FUEL-INJECTOR | |
| WAIT TO START LIGHT | N/A | | |
| BRAKE | WHITE/ TAN (+) | @ FUSEBOX, BLACK Plug, Pin 19 | |
| FACTORY ALARM DISARM | DISARMS with FACTORY REMOTE ONLY!! | | |
| ANTI-THEFT | CHRYSLER'S SENTRY KEY, TRANSPONDER SYSTEM, See NOTE *6 | @ IGNITION SWITCH TUMBLER | |
| NOTES |
| NOTE *1 the PURPLE (-) Accessory wire must be powered up using an extra Relay Part 775, See DIAGRAM NOTE *2 the (-) Negative Parking Lights on this Vehicle require a (-) Negative or Ground thru a 1100 Ohm Resistor a Relay Part #775 must be used, to Connect See DIAGRAM.NOTE *3 the (+) Positive Parking Lights on this vehicle require adding (2) Extra Relays Part #775 to turn ON both the Left and the Right Parking Light circuits in this vehicle, See DIAGRAMNOTE *4 this vehicle uses a 1-Wire Door Locking System, a (-) Negative thru a 330 Ohm Resistor will LOCK and (-) Negative thru a 100 Ohm Resistor will UNLOCK, if your unit DOES NOT have On-Board Door Lock Relays, (2) Extra Relays Part #775 will be required, See DIAGRAM.On vehicles without memory Seats, the Lock/Unlock wire can be found in the Drivers Kick Panel at the Door Harness. With Memory Seats, this wire is located in the Drivers Door at the Drivers Door Memory Mirror Module.NOTE *5 DRIVERS Front door is a PURPLE (-). The PASSANGER Front Door is a PURPLE / WHITE (-). The DRIVERS REAR Door is a PURPLE / GRAY (-) and the PASSANGER REAR Door is a PERPLE / YELLOW (-). Tje REAR DOOR Trigger wires are located in a LARGE 74-Pin Plug near the FUSEBOX. For the FRONT DOOR Trigger wires: On vehicles without memory Seats, the FRONT DOOR Trigger wires are located in the same 74-pin plug as the REAR DOOR Triggers. With Memory Seats, the DRIVERS DOOR Trigger wire is located in the Drivers Door at the Drivers Door Memory Mirror Module. the PASSENGER DOOR Trigger wire is located in the PASSANGER DOOR at the PASSENGER MEMORY MIRROR MODULE. When connecting to an Alarm system use all 4 wires and DIODE ISOLATE, See DIAGRAM NOTE *6 CHRYSLER'S SENTRY KEY, TRANSPONDER SYSTEM is Standard on the LIMITED and SLT V8 Models and Optional on the Adventurer and on the SLT V6 Models. |
Southern Stylez
Jacksonville, FL 32218
Wednesday, April 22, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
