prostart ct 3310 88 camry
mkee
Member - Posts: 7
Posted: January 28, 2008 at 11:04 PM / IP Logged
Im installing a Prostart ct 3310 on my 88 Camry and like to know how I can hook up the wires so only the driver door opens first and then the rest with a second click, is it the blue/white wire, where do I connect this to?
Also a purple wire to connect? Seems like lots of wires I dont need to connect.
Thanks in advance
dusco
Member - Posts: 10
Posted: January 28, 2008 at 11:17 PM / IP Logged
most cars that i have done, was already set up from factory to double pulse to unlock the doors. all i had to do was program my aftermarket unit to do the same. one pulse driver door unlock, double pulse for all other doors. i think some cars will let you do this and some wont. as for your wire colors i cant help you. just hang in there someone will be by in a few to give you better info than i have.
Sunday, February 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
