2004 pathfinder key sense
saskpuller
Copper - Posts: 144
Posted: February 07, 2008 at 6:51 PM / IP Logged
I've got a Pathfinder coming in next week and would like to know what the powering up the keysense wire + is all about. I've only seen reference to this on the Astrochart. Is this required? If so, what do program this relay to? Is it a pulse or maintained positive? I will be using a PKN2 bypass if it matters.
KarTuneMan
Platinum - Posts: 7,056
Posted: February 07, 2008 at 7:54 PM / IP Logged
In the astrochart you'll see that the rig arms and disarms with lock and unlock. You power up the key sence with ground while running and a relay (for pos. trigger) to disarm without unlocking the doors.
saskpuller
Copper - Posts: 144
Posted: February 07, 2008 at 7:58 PM / IP Logged
So 86 & 87 positive, 85 GWR and 30 to the keysense wire. Correct?
chadwa2003
Copper - Posts: 353
Posted: February 07, 2008 at 10:07 PM / IP Logged
Yeah that's correct
Chris Luongo
Platinum - Posts: 3,746
Posted: February 08, 2008 at 1:29 PM / IP Logged
They list the keysense wire on almost every car, whether you need it or not.
No need on that Pathfinder. It'll disarm all by itself with remote start.
