train horns 05 f350
hzemall
Copper - Posts: 55
Posted: February 09, 2008 at 12:42 PM / IP Logged
Quick Question:
On this truck there are 4 aux switches on the dash, I want to be able to activate the train horns with one of these switches, how do I wire a relay for this
Tim Baillie
Installer/Designer/Fabricator
Certified Autosound & Security
tedmond
Gold - Posts: 4,610
Posted: February 10, 2008 at 7:33 AM / IP Logged
using your switch and relay wire up like so.
switch will send negative out to relay.
85 - ground from switched source
86 - constant 12v
87 - high current 12v
30 - to positive wire of horn.
ground the horn negative wire.
Tuesday, October 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
