avic-n1 navigation points of interest
pioneerfan
Member - Posts: 22
Posted: February 13, 2008 at 12:49 AM / IP Logged
Yes i currently own a AVIC-N1 and i got everything hooked up bestids the speed sensor. figured i didnt need it for the navigation.  but the problem is. when i put the navigation disc in it reads them but when i pull them out and access the navigation it dont show me where gas stations, grocery stores.. etc... was wondering how i get all this my gps is just all little lines and thats it.. idk help would be appreciated.
h2oskierfl
Copper - Posts: 87
Posted: February 16, 2008 at 11:42 AM / IP Logged
You will only get detailed map info (POI's and close up views) with the navigation DVD in the drive. Also, you will want to hoop up the VSS wire if possible. This will give you much better accuracy for the GPS.
pioneerfan
Member - Posts: 22
Posted: February 16, 2008 at 2:15 PM / IP Logged
vss wire/?? what is this wire. what does it do.. do i need it how do i hooki t up ?
h2oskierfl
Copper - Posts: 87
Posted: February 16, 2008 at 2:20 PM / IP Logged
You dont technically need it, but it will make your GPS much more accurate. Its the pink wire coming off the harness labled speed sense. Its hooked to the cars computer and tells the AVIC how fast the car is actually moving. Without the wire hooked up, it can only sense speed by checking the GPS satellites which can cause a delay.
pioneerfan
Member - Posts: 22
Posted: February 16, 2008 at 2:23 PM / IP Logged
where is the vss wire on a 1998 ford escort zx2?
pioneerfan
Member - Posts: 22
Posted: February 16, 2008 at 2:30 PM / IP Logged
where can this wire be loacated
h2oskierfl
Copper - Posts: 87
Posted: February 16, 2008 at 2:40 PM / IP Logged
That all depends on the car. Every one is different.
pioneerfan
Member - Posts: 22
Posted: February 16, 2008 at 2:42 PM / IP Logged
1998 Ford Escort ZX2
flobee4
Silver - Posts: 585
Posted: February 17, 2008 at 10:43 AM / IP Logged
VSS Wire: PCM - 104 PIN CONNECTOR POSITION 58
VSS Wire Color: WHITE/ BLACK
Powertrain Control Module (PCM) Located Below Center Console
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
