jl audio 12w3 4 ohm dvc sub
huerdo623
Member - Posts: 8
Posted: March 09, 2008 at 9:46 PM / IP Logged
 I recently purchased a jl audio 12w3 4 ohm dvc and come to find out one voice coil has been shorted out,my question is this what can i do to it can i run it with either a hcca 12 dvc 2ohm or my other jl audio dual 4 ohm to an extreme orion 800 or am i screwed?
aznboi3644
Gold - Posts: 2,600
Posted: March 10, 2008 at 12:25 AM / IP Logged
I'd return the sub if one coil is messed up
huerdo623
Member - Posts: 8
Posted: March 10, 2008 at 5:48 AM / IP Logged
i've been reading this stuff on people shorting out a voice coil,is there anyway to reverse it
huerdo623
Member - Posts: 8
Posted: March 10, 2008 at 6:39 AM / IP Logged
bth the equiptment i have to work with is 2 jl audio 12w3 dual 4ohm voice coils or a 1999 12inhcca dual 2ohm voice coils to the extreme800 orion from the 90s if that helps, should i use 1 12 running 800 watts or 2 12s running 400 watts each,which setup is louder?
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: March 10, 2008 at 11:35 AM / IP Logged
When people intentionally short out a coil they would put a wire on one of the set of terminals.  If this was the case with your sub then it should be obvious and easy to remove the wire.
Steven Kephart
Posted: March 10, 2008 at 11:41 AM / IP Logged
800 watts is too much power for the 12W3.  I would recommend running both subs off that amp.
huerdo623
Member - Posts: 8
Posted: March 10, 2008 at 1:14 PM / IP Logged
there is no wire so i guess the voice coil is burnt but the other works fine
Sunday, December 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
