avic n4, 2003 saturn vue
lostparts
Posted: March 09, 2008 at 11:38 PM / IP Logged
I Have a Pioneer AVIC N4 that I will be putting in a 2003 Saturn Vue with Auto trans and 3.0L V6. I have a wire diagram but can't figure out where to hook the speed pulse or VSS. The diagram shows the right front wheel speed sensor with a TAN wire And dark green wire they are going to a wheel speed signal conditioner module. the module has black ground a white wire going to the ECM and a pink wire from the fuse block. What I can't figure out should it be hooked to the White wire going to the ECM the Tan wire (A) or dark green (B) going to the wheel speed signal conditioner module
Roger Clement
lostparts
Posted: March 26, 2008 at 10:22 AM / IP Logged
Found the answer to which wire to hook to for the VSS on the 2003 Satrun Vue (without ABS Brakes). It is the (White wire) going from the wheel speed signal conditioner module to the engine control module. best place to get to it is behind the left front console trim panel.
