Mitsubishi 3000 GTO
philt
Posted: March 02, 2003 at 8:16 AM / IP Logged
Does anyone have an engine management wiring diagram for a '91 model?
I have an intermittant non start fault - engine cranks but no spark/fuel, usually recovers after period of time.When fault on turbo boost gauge goes full scale.Suspect a problem on power side, supply to ecu,but need more info.
Thanks,
Phil.
Russ_Aldous
Posted: March 05, 2003 at 4:48 PM / IP Logged
Phil,
I've got a similar problem but with a non turbo GTO. No spark and no feed to the injectors. Logic dictates that this could be the ECU, Timing position sensor or some sort of imobiliser. (amongst other things)
Please let me know if you find out the cause.
Cheers
Russ
Russ Aldous
Platinum - Posts: 12,488
Posted: March 05, 2003 at 9:12 PM / IP Logged
If the battery is good and there is start but no run ( eg. the starter motor sounds good and no power loss ) then check the distributor cap for crack & also look into ignitor coil and ICM ( Ignition Control Module ) located inside the cap.
