compustar alarm/starter, 04 3500 silverado
deadtired80
Member - Posts: 8
Posted: March 12, 2008 at 1:22 AM / IP Logged
i have a 2004 3500 silverado diesel and a compustar 2w900fm-as with a data link ads-gm1 bypass module. so i was wondering if anyone could do up a line diagram for me as i'm not too sure with alarms
thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: March 13, 2008 at 9:56 AM / IP Logged
This is why this product isn't supposed to be sold over the counter. And only sold installed. good luck.
Wire/FunctionCM3000ColourLocation/DescriptionPolarity
 PASSIVE ANTI-THEFT BLACK (CN2) YES PASSLOCK 2  SEE NOTES
 12 VOLTS RED (CN1) Red Ignition switch harness
 IGNITION GREEN (CN1) Pink Ignition switch harness
 IGNITION 2 GREEN (CN2) + Relay White Ignition switch harness
These wire are smaller the other wires from the ignition switch. Test carefully.
 ACCESSORY WHITE (CN1) Orange Ignition switch harness
 STARTER YELLOW (CN1)  Yellow Ignition switch harness
 KEY SENSE  Lt.green At steering column
 TACH SIGNAL YELLOW/BLACK (CN3) SEE NOTES
There is a coil for each cylinder, each with a 4-pin plug. Each plug contains a BLACK, BROWN & PINK, as well as a 4th wire which changes color on each coil. This 4th wire can be used as your tach reference, set your remote starter for a 1 cylinder signal.
 DIESEL TACH SIGNAL  White Pin-A2 behind instrument cluster  AC
 FUEL INJECTOR  Opposite of Pink wire At any injector on engine  AC
 LOCK BLUE/BLACK (CN4) SEE NOTES
The doorlocks are Class 2 Data on this vehicle and cannot be interfaced directly. Interface modules for both doorlocks and security are available for this vehicle. Contact your supplier for more information.
 UNLOCK BLUE (CN4) SEE NOTES
 GLO-PLUG SIGNAL BRN/WHITE(+) or BROWN(-) (CN3) Dk.blue Behind instrument cluster
 DOORPIN RED / WHITE(-) or RED(+) (CN3) Gray/black At courtesy light under dash
 FACTORY ARM ORANGE (CN5) SEE NOTES
 FACTORY DISARM ORANGE / WHITE (CN5) Lt.green At driver's door module
Part of switch assembly inside driver's door.
 BRAKESWITCH LT.BLUE/WHITE (CN3) White At switch above brake pedal
 PARKLIGHTS GREEN / WHITE (+) (CN1) or (-) (CN2) Gray/black At light switch harness
 HAND BRAKE LT.BLUE (CN3) Manual only Lt.blue At switch on handbrake lever
 HORN WHITE (-) (CN5) Black At steering column
 VSS WIRE  GREEN/ black At PCM left front of engine compt.  AC
 DATABUS INTERFACE  Pin-2(top row from left) Diagnostic plug below dash  DATA
 PASSLOCK DATA  Yellow In 3 wire harness from ignition switch  DATA
 PASSLOCK GROUND  Black or ORANGE / black In 3 wire harness from ignition switch
deadtired80
Member - Posts: 8
Posted: March 27, 2008 at 3:54 PM / IP Logged
ok
i have a few questions
Q1. on the idatalink ads-gm1  the ground output when running ,door status output, tach output , and ignition input,where do these 4 wires go on the alarm system
q2.on the alarm cn1/ pin3 RED / white 12v constant  does this go to the same place as cn1/pin1
q3. on the alarm again all the wires on cn2 light output, status output, 2nd ignition output, 2nd acc output, 2nd starter output where do these go
thanks
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
