2006 nissan murano, remote start
malibudee
Member - Posts: 6
Posted: March 14, 2008 at 5:20 AM / IP Logged
Does anyboby know where the key sense gets connect to on the remote start  or alarm (avistat)
Thanks a Million
tedmond
Gold - Posts: 4,610
Posted: March 14, 2008 at 8:01 AM / IP Logged
if you want to use keysense to disarm the alarm test it to see if its negative. If so, connect your ground when running wire to the keysense on the car.
KarTuneMan
Platinum - Posts: 7,056
Posted: March 14, 2008 at 2:58 PM / IP Logged
The keysence is RED / blue, or BLACK/ red @ the BCM, pin 24 @ the 40 pin white plug. It's (POS)+
This vehicle disarms when the ign. it energized.
malibudee
Member - Posts: 6
Posted: March 14, 2008 at 11:45 PM / IP Logged
Thanks for the response Fellas, But do i need to hook this up in the 2006 murano on the wiring daigram i have it does have anywhere to get hook up to it just blank (Please help...
tedmond
Gold - Posts: 4,610
Posted: March 15, 2008 at 7:03 AM / IP Logged
there is the 04 on the site, but not sure if its the same. Your best bet is ask KarTuneMan, he has up to date diagrams.
JWorm
Platinum - Posts: 2,208
Posted: March 15, 2008 at 10:21 AM / IP Logged
You don't need to hook it up.
KarTuneMan
Posted: March 15, 2008 at 10:39 AM / IP Logged
2006 nissan murano, remote start -- posted image.
Chris Luongo
Platinum - Posts: 3,746
Posted: March 15, 2008 at 10:58 AM / IP Logged
More information is needed.
1. What are you using for transponder bypass.
2. Does your Murano have the Intelligent Key?
malibudee
Member - Posts: 6
Posted: March 15, 2008 at 7:30 PM / IP Logged
it does have the intelligent key so what i did was hook up the bypass to the keysense wire in the vehicle
so for you guy are the best im donation to this site just on the note you guys cleared this up for me
