fuse blownin
Xtremesize1978
Member - Posts: 27
Posted: March 02, 2003 at 1:45 PM / IP Logged
I've got a PG XS2500,it has 2 30amp. fuses...They blow when I turn it up pretty good.....What do I do?
bigmikeww
Copper - Posts: 75
Posted: March 02, 2003 at 7:44 PM / IP Logged
do you have it hooked up right? batt.,ground,remote.
do you have the ground and the batt. reversed?
double check and make sure you have the right wire were it goes.
bberman1
Gold - Posts: 2,314
Posted: March 02, 2003 at 7:54 PM / IP Logged
Also check to see if the subs are wired correctly!
Xtremesize1978
Member - Posts: 27
Posted: March 03, 2003 at 11:40 AM / IP Logged
Thanks alot
bberman1
Gold - Posts: 2,314
Posted: March 03, 2003 at 4:50 PM / IP Logged
Have you located the problem yet?
