00 eclipse rs cd player wiring
mcmaro
Posted: March 26, 2008 at 12:51 PM / IP Logged
bought my eclipse about 2 weeks ago while the cd player wasnt hooked up i can usually hook them up without breaking a wire strand. but this time im just clueless nothing matchs. looked on the net for diaphrams but none helped. heres the wire info.
Dash wire colors.
Black striped blue
yellow striped red
orange striped black
black striped yellow
black striped red
green striped white
white striped black
gray striped blue
white striped red
gray striped red
yellow striped blue
CD wire colors.
white
green
purple
gray
gray striped black
blue striped white
blue
red
black
white striped black
green striped black
purple striped black
gray striped black
yellow
techman93
Silver - Posts: 591
Posted: March 26, 2008 at 11:00 PM / IP Logged
Is the CD player factory? If it is an after market then the colors would be
white        left front(+)
WHITE/ black left front(-)
gray        right front (+)
gray/black   right front (-)
green        left rear (+)
GREEN/ black left rear (-)
purple       right rear (+)
PURPLE / black right rear (-)
red          12v+ acc
yellow       12v+ constant
black        ground
blue        remote turn on
blue/white   power antenna turn on
Audiovox states the car code for 2000 mitsubishi eclipse is:
Battery             RED / BLACK   (+)     RADIO HARNESS
Accesory     BLUE        (+)     RADIO HARNESS
Ground          BLACK        (-)     RADIO HARNESS
LF Speaker (+)          WHITE/ LIGHT BLUE
LF Speaker (-)          BLACK/ BLUE
RF Speaker (+)          WHITE/ RED
RF Speaker (-)          BLACK/ RED
LR Speaker (+)          YELLOW/BLUE
LR Speaker (-)          GRAY/BLUE
RR Speaker (+)          YELLOW/RED
RR Speaker (-)          GRAY/RED
Amp Location          NOT LIKELY
Radio Security          YES
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
mcmaro
Posted: March 27, 2008 at 11:33 AM / IP Logged
its sony 5 drive.
the problem is i got the info on what the speaker wires are, but after all that i have 3/4 wires left over.
red,blue ( not antenna ),yellow
unsure what to connect them to, the info you gave helps me but doesnt give me really what im looking for, im looking for the lazy way out, prelisted on what wires hook to each other.
mcmaro
Posted: March 27, 2008 at 2:47 PM / IP Logged
heres the set up i got now.
PURPLE / black to gray/red
purple to yellow/red
gray to BLACK/ red
gray/black to WHITE/ red
white to WHITE/ blue
WHITE/ black to black blue
green to yellow/blue
GREEN/ black to gray/blue
blue/white to ??
yellow to ?? ( im sure of seeing a plastic covering with the words "amp on? "
black ( not the ground on back of the metal plate ) to ???
red to ???
the colors i got left from the dash are
ORANGE / black
GREEN / WHITE
and either 2 or 1 more. unsure of.
