10 kenwood sub done?
blownpsd
Member - Posts: 14
Posted: March 27, 2008 at 4:53 PM / IP Logged
 I have a 10" Kenwood DVC sub that I bought new and it has played a total of 10 minutes- 5minutes before burning one amp and 5 minutes before burning another.  I thought maybe after the first one that maybe the amp was just crap (ebay buy) bought another one after having repaired it and burned it down too.  Before this went any further, I took the sub to the place I bought it today and asked them to check it out- he checked the wiring (I had it wired positive to positive, neg to neg, so he said that was alright- he checked the resistance of the coils with the wires hooked together and it read 1.5 ohms, with the wires diconnected one coil read 3 ohms and the other read 2.9 ohms.  He said the sub is garbage.  Is he right?  The coils were supposed to be 4 ohms each.   If so what sub do you recommend (10") for the 225 hcca orion being bridged.  I want SQ not SPL.  Loud is great too though lol!
___________________________________________
always need more power
Platinum - Posts: 13,720
Posted: March 27, 2008 at 7:23 PM / IP Logged
The impedance of the coils are 4 ohms.  The resistance of the coils are obviously 2.9 and 3.0 ohms.   Impedance is an AC measurement.  Resistance is a DC measurement.   The woofer is fine.
blownpsd
Member - Posts: 14
Posted: March 28, 2008 at 12:12 AM / IP Logged
any idea why it would blow up two amps back to back? is my wiring right on the sub?  pos to pos neg to neg note that it is a dvc sub 4 ohms each, should be 2 ohm load to amp.  maybe I did not bridge those alpine amps right?
haemphyst
Platinum - Posts: 5,059
Posted: March 28, 2008 at 12:19 AM / IP Logged
An amplifier, when bridged into a 2 ohm load, "sees" 1 ohm per channel, which the Alpines will not support safely.
Yeah, that'll blow an amp.
blownpsd
Member - Posts: 14
Posted: March 28, 2008 at 1:51 AM / IP Logged
this is news to me, what I have always understood is 2 4ohm vc wired in parallel will make a 2 ohm load for the amp.  How is this going to affect the 225 hcca?
Posted: March 28, 2008 at 4:08 AM / IP Logged
The hcca will be fine.  The HC at the beginning is for High Current.  I don't know what Alpine amp you had but not many of them will play at 2 ohms mono, or 1 ohm stereo which is the same identical load.
Monday, September 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
