2000 impala remote start problem
hydrodancer91
Copper - Posts: 72
Posted: April 05, 2008 at 9:59 PM / IP Logged
yes its grounded to the ground and the dash by the ignition switch where a bunch of the factory grounds are.
tedmond
Gold - Posts: 4,610
Posted: April 05, 2008 at 10:37 PM / IP Logged
some GM cars are weird. Try powering up keysense and see if that will allo it to remote start. some newer GMs, if the car doesnt detect a key is in tthe igniton, it wont start
wentworth007
Member - Posts: 33
Posted: April 07, 2008 at 7:52 PM / IP Logged
what kind of connection are you using? T tap, solder i would suspect that the connection is bad and not getting voltage to the wire.
