new speaker vibrates sounds blown
bigcasino
Posted: April 01, 2008 at 10:37 PM / IP Logged
I look all over the forums and could not find an answer. I have a 2001 GMC Jimmy 2dr with a stock delco Am/Fm Cd player. I went out and bought some Jensen 6.5 coaxils for the doors and 6x9 triaxils for the rear panels, because I had one 6x9 right side not working and one door speaker (right side) was starting to make noise. When wiring the speakers I used the wiring color codes from this site and the manufactures instructions to the letter. Now when I finished and turned on the system all 4 speakers work but I am getting a Vibrating noise out of the right rear 6x9 speaker only (at normal volume), Bass and treble are equaled between left and right sides, so are the fade and balance. It gets worse the louder you go and is not as bad in lower volume ( it sounds blown to me). I disconnected each speaker and ried the radio to see if any others were doing it as well and they were all good, it is just that right rear 6x9 speaker. Anyone have any Ideas before I take my truck all apart and remove the speakers to return them. THANKS!!
Big Casino
sedate
Silver - Posts: 1,173
Posted: April 01, 2008 at 10:57 PM / IP Logged
I dunno.
Maybe that channel was going bad on ur head unit . . . ?
Run some open-cell weatherstripping around the edge of the speaker basket and reinstall it . . . ?
There really isn't enough information here to go on.
aznboi3644
Gold - Posts: 2,600
Posted: April 01, 2008 at 11:25 PM / IP Logged
is it possible that the rattling noise is due to poor installation???
bigcasino
Posted: April 02, 2008 at 12:44 AM / IP Logged
I installed it using the OEM hardware and it is tight. it is installed exactly the same as the left side and the left side is good.
What other info do you need?
Big Casino
bigcasino
Posted: April 02, 2008 at 12:48 AM / IP Logged
It doesn't rattle, it  is a vibration like there is to much bass, but the bass is not to high and it only happens in the one speaker. All others are ok..
Big Casino
bigcasino
Posted: April 02, 2008 at 1:09 PM / IP Logged
Could the problem be from going from a 10 Ohmn speaker to a 4 Ohmn speaker? will swap out speaker tonight to make sure it is the speaker. hope it is not the head unit, but if it is does anyone have a good suggestion for a replacement?
Big Casino
Alpine Guy
Platinum - Posts: 2,478
Posted: April 02, 2008 at 2:03 PM / IP Logged
Stock was 10 ohm, and you replaced it with 4 ohm? Theres your first problem, sounds like you have the Bose option? If thats the case you need to replace with the same crappy blows speakers, or get a new headunit and run new wires directly to the aftermarket speakers.
Those speakers are absolutly junk, you got what you paid for, most likely a blown speaker, I have seen that many times, people would bring me crap they bought from wal mart and they were blown right out of the box. Seriously, save your ears from the horrible pain those speakers will produce and return them, $20-$50 more at a stereo shop and you will get MUCH better speakers, if you plan to get a new head unit, but if not, then you need to find 10 ohm speakers or you will fry your factory head unit/amp.
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
