2006 dodge charger door triggers
all out customs
Member - Posts: 11
Posted: April 28, 2008 at 7:15 PM / IP Logged
I am trying to follow the guidelines that directtechs points out, but I can't seem to find the door triggers.  Are these the right colors:
LF-PURPLE IN WHITE PLUG PIN 3
RF-PURPLE WHITE IN WHITE PLUG PIN 16
LR-PURPLE / GRAY IN GRAY PLUG PIN 10
RR= PURPLE YELLOW IN GRAY 26 PIN PLUG PIN 9
????  DOES THE ALL DOOR TRIGGER WORK AS WELL??
Thanks in advance.
mikvot
Gold - Posts: 1,043
Posted: April 28, 2008 at 7:40 PM / IP Logged
Those colors are correct. The plugs listed would be found at the back of the instrument cluster.
KarTuneMan
Platinum - Posts: 7,056
Posted: April 28, 2008 at 7:41 PM / IP Logged
That is what Astro shows.... What bypass are you using? does it have a door sence output?
dtk1
Copper - Posts: 179
Posted: April 28, 2008 at 8:59 PM / IP Logged
if this car has a factory amp it should be right next to it cant missed it for the pasanger theres another plug right behind the glove box a little bit lower you should be able to see it
fcss
Copper - Posts: 92
Posted: April 29, 2008 at 2:04 PM / IP Logged
If you dont want to tag all the door triggers, you can use Yellow/White (+) in harness in driver kick it does all the doors not the trunk, it is the dome light wire so it has a delay.
all out customs
Member - Posts: 11
Posted: April 29, 2008 at 11:02 PM / IP Logged
Thanks guys for all your feedback, I found the door triggers eventually as I was testing them one by one.  For some reason the LR, PURPLE / Gray for this particular car looked to me like purple white.  The driver side triggers were found on a black plug with a white locking clip.  The passenger side was a white plug.  Once again thanks for all the feedback.
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
