tach signal on a 2004 audi a4
da_reeseboy
Posted: May 07, 2008 at 5:15 PM / IP Logged
I am installing an HKS Turbo Timer (type 1) on my wife's 04 A4 1.8t. I have searched and found wiring info saying to use the injectors or ignition coil signal wire. Using either an injector or signal wire on a coil pak it only reads 1/3 of the actual RPM. Is there another source, perhaps on the back of the gauge cluster, that I can get a signal?
- Jesse
dtk1
Copper - Posts: 179
Posted: May 07, 2008 at 7:15 PM / IP Logged
Tachometer     NOT RED / blue or BLACK/ blue        any fuel injector
da_reeseboy
Posted: May 07, 2008 at 7:32 PM / IP Logged
As I said, I tried that already. Off the fuel injector, it is only reading 1/3 rpm.
- Jesse
Posted: May 08, 2008 at 5:20 AM / IP Logged
That should be adequate, if not check pins on engine management, one will be tach.
da_reeseboy
Posted: May 08, 2008 at 10:28 AM / IP Logged
Does anyone have the ecu pinout? That would help greatly.
- Jesse
da_reeseboy
Posted: May 09, 2008 at 12:33 PM / IP Logged
I guess no one has the pinout? bummer...
- Jesse
