experience with directed amps?
jmelton86
Gold - Posts: 1,228
Posted: May 08, 2008 at 6:57 PM / IP Logged
http://www.directedxtreme.com/amplifiers/xa8001.asp
Has anyone had experience with this manufacturer? My work recently started carrying Directed Xtreme amps. The largest amp we carried prior to this was JensenJPA285 (250watts RMS *CEA* bridged 4ohms -30amp fuse). Since this XA8001 is rated for 302watts RMS *CEA* at 4ohms (2ohm stable - 420watts @ 2ohms -60amps of fusing), I figured 'WTH' and got it.
It is a bit louder than the 250watt amp I had prior, so it's worth it to me. Also, i'm only loading it @ 4ohms instead of 2, so I have a little better damping.
The only thing is, it's not very efficient. Even @ 4ohms it gets pretty hot! I'm going to install a PC fan in the near future.
Comments?
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
chillin420
Copper - Posts: 236
Posted: May 08, 2008 at 7:47 PM / IP Logged
return it.  directed stinks.  have had nothing but problems with this manufacturer.
you can do it....
advanced MECP, lol does it really matter....
patience is a virtue
jmelton86
Gold - Posts: 1,228
Posted: May 08, 2008 at 7:50 PM / IP Logged
Is it because they are so inefficient (it gets hot!)?
I plan on adding a fan...(?)
Big3 in 1/0G
1/0G to GTO14001
chillin420
Copper - Posts: 236
Posted: May 08, 2008 at 7:59 PM / IP Logged
no i have never had one last more than a month.  sold them a lot at last shop i worked at and they always came back.  they are a "swap meet special" persay
you can do it....
jmelton86
Gold - Posts: 1,228
Posted: May 08, 2008 at 8:05 PM / IP Logged
Oh, well. I guess i'll make the fan removable w/out making any 'holes'. -I can switch it out through my work if need be.
Thanks for the heads-up! I did wonder why it gets hella-hot only loaded @ 4ohms -2ohm stable.
Big3 in 1/0G
1/0G to GTO14001
haemphyst
Platinum - Posts: 5,059
Posted: May 08, 2008 at 8:51 PM / IP Logged
per se
But, yeah. Garbage. Louder? What about the distortion figures? I have often noticed that systems with more distortion will often sound louder, with the same amount of power.
I'd get rid of it, personally.
jmelton86
Gold - Posts: 1,228
Posted: May 08, 2008 at 8:54 PM / IP Logged
I got this, KarTuneMan;
The Spiz attacks again!
Big3 in 1/0G
1/0G to GTO14001
haemphyst
Posted: May 08, 2008 at 9:08 PM / IP Logged
W... O... W...
experience with directed amps? -- posted image.
KarTuneMan
Platinum - Posts: 7,056
Posted: May 08, 2008 at 9:24 PM / IP Logged
Well...... I just got here. I am, at this time, rolling on the floor...........experience with directed amps? -- posted image.
jmelton86
Gold - Posts: 1,228
Posted: May 08, 2008 at 9:30 PM / IP Logged
Don't do that on the floor, mane! El Oh EL
Well, i'm glad I asked as i've heard before that Directed amps are crap. I guess i'm going to see if the fan helps... I'll keep the other amp on standby.
Big3 in 1/0G
1/0G to GTO14001
