viper 5701 and 1701g 2007 yukon denali
peterubers
Silver - Posts: 706
Posted: May 16, 2008 at 9:48 AM / IP Logged
The feedback is likely secondary to the bypass unit -- they need to diode isolate a keysense wire (if that's part of the setup) or the status input on the 1701g module....
The search function is your friend.
scottieny
Member - Posts: 6
Posted: May 19, 2008 at 10:33 AM / IP Logged
So I had started a thread on issues after having the Viper 5701 installed in my 2007 Denali. It seems that the alarm related issues have been resolved with the exception of the following...
Any time I manually turn on the headlights the dome lights turns on as well and stays on. The dome lights have a separate on and off switch. I also noticed after getting the alarm installed if I open any doors that the dome supervision light does not turn on, it only turns on for 30 seconds after unlock the car using the remote.
The dome supervision light used to work perfectly prior to having the alarm installed. Would any one know what the installers did wrong?
