2001 Dodge Stratus wiring diagram
teald024
Posted: May 30, 2002 at 9:36 PM / IP Logged
I need the electrical diagram for a 2001 Dodge Stratus R/T with the Infinity radio.  I am having trouble with the speakers and would like to troubleshoot the electrical system.  Does anyone have one or know where I can get one?
trusdamanr
Copper - Posts: 116
Posted: May 31, 2002 at 5:17 PM / IP Logged
DODGE STRATUS 2001
WIRE COLORSLOCATION
12 VOLTS CONTANTRED or PNK/BLURED / BLU IGN SWT HARNESS
IGNITION 1DK.BLUIGNITION SWITCH HARNESS
IGNITION 2GRN/REDIGNITION SWITCH HARNESS
IGNITION 3IGNITION SWITCH
ACCESSORY /HEATER BLOWER 1ORG/BLKIGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2
STARTERYELIGNITION SWITCH
PARKING LIGHTSBLK/YEL (+)DR KICK PANEL
DOMELIGHTYEL (-)UNDER FUSEBOX
PWR DOOR LOCKWHT/LT.GRNNEAR FUSEBOX
PWR DOOR UNLOCKWHT/LT.GRNSINGLE WIRE LOCKS *SEE DIAGRAM*
TRUNK RELEASEBLK/WHTDR KICK PANEL
TACH SENSORBLK/GRY (-)or BLU/GRY
BRAKEWHT/TAN (+)AT BRAKE SWITCH
HORNGRN/BLK (-)AT STEERING COLUMN
FACTORY DISARMLT.GRN/ORGLFT SIDE OF DASH
heres the diagram  what kind of problem are you having with the speakers
teald024
Posted: June 01, 2002 at 1:55 PM / IP Logged
  Well, to put it simply, the right rear speaker does not work.  I disconnected the wire from the speaker and used an ohm meter to check the continuity of the speaker.  it was OK.  Then I checked the voltage at the connector, it was minimal (less than 10mV). I pulled the deck out of the dash and there was a power harness and a speaker harness.  This car has 7 speakers and there was only 7 wires in the speaker harness.  I wanted the diagram for the audio system to see how the system was wired. I wasn't sure if the infinity system used an external or internal (to the deck) anplifier.
I have located the amp under the front passenger seat. I found the wires that matched those for the correct speaker.  There was the same 10mv at the pins for the line level output.  From testing the other rear speaker, at the same volume level,  the signal should have been at about 100mV.  Therefore, I can only conclude that channel on the amp is fried.  Come to think of it, I did not check the output signal from the deck.
I bought the car with 12000 miles on it, so the last guy must have f****ed it up.  I am debating weather to contact the dealer, or just move up my time table for installing new components.  (2 subs, 2 amps, new speakers and head unit).  I am leaning toward the later.  Do you know if and what part of the audio system is covered under warranty?  I would still like the diagram for the audio system if you have it (jpeg or the like).
