current needed for 800w car amplifier?
ktennessen
Posted: May 18, 2008 at 8:37 PM / IP Logged
I'm trying to hook up some car subs to my home theater. I have some 120V AC to 12V DC converters lying around. The current output on some of the converters are adjustable so I just need to know the current output from the converter that is necessary to run an 800W car amplifier. I understand that I=P/E, but I'm not sure how to apply the numbers in this situation. I need the current necessary from the converter to the amplifier, not from the amplifier to the speakers.
Platinum - Posts: 13,726
Posted: May 18, 2008 at 9:13 PM / IP Logged
It would help if we knew the brand of the amp. How many amps is the power supply rated at?  You will need at least a 35 amp supply, and this may not be enough to get max power from the amp.
ktennessen
Posted: May 18, 2008 at 9:40 PM / IP Logged
Its a Boss SE550 400Wx2 @ 2 ohms. I can't find the current rating online and I don't have the amp with me to see if its on there anywhere.
haemphyst
Platinum - Posts: 5,059
Posted: May 18, 2008 at 9:43 PM / IP Logged
Whatever the fuses in the end of the amp total. If you have two 20A fuses, (pretty likely, as it is a Boss amp, and SPECTACULARLY over-rated) then you would need 40A worth of current. If not planning on running it WFO, ever, then you would simply buy as big a power supply as your pocketbook can support.
Posted: May 18, 2008 at 9:57 PM / IP Logged
35 and above amp power supplies are not the norm.
the12volt
Administrator - Posts: 3,959
