Key-free listening relay diagram
epicminis
Member - Posts: 14
Posted: March 06, 2003 at 9:02 PM / IP Logged
 Hi to all, i'm looking for a diagram that shows how to wire relays so that when you turn off your vehicle, the radio stays on until you open the door. I did this years ago, but have forgotten exactly how to wire the relays up. Any help especially a diagram would be appreciated!
cpgoose
Gold - Posts: 1,098
Posted: March 07, 2003 at 7:42 AM / IP Logged
hey, I believe this is what you're looking for. I have no idea if it works or not, I'm just the messenger Key-free listening relay diagram -- posted image.
https://www.the12volt.com/installbay/forum_posts.asp?tid=9724&KW=radio+door+open
the12volt
Administrator - Posts: 3,959
Posted: March 07, 2003 at 8:22 AM / IP Logged
Key-free listening relay diagram -- posted image. the12volt • Support the12volt.com
the12volt
Posted: March 07, 2003 at 8:28 AM / IP Logged
Edited: Just a note, to prevent other circuits that share the radio's accessory lead from seeing 12V+ when the key is off, cut the accessory lead and add two 1 amp diodes as shown below.
epicminis
Member - Posts: 14
Posted: March 07, 2003 at 2:34 PM / IP Logged
THANKS GUYS! That's what I needed. You guys RULE.
the12volt
Posted: March 07, 2003 at 2:50 PM / IP Logged
You're welcome, however, my second diagram has a problem. If the key is on, the radio will turn off when you open the door. I'm about to head out , but as soon as I get the chance, I'll post an updated version here.
the12volt
Posted: March 07, 2003 at 4:11 PM / IP Logged
Here's the fix to isolate the radio frrom anything else on the same circuit without it turning off when you open a door with the key in the accessory position.
themagicone
Silver - Posts: 325
Posted: March 07, 2003 at 4:37 PM / IP Logged
there is also a solid state eltronic chip you can use 525 timer or something like that, search around.
