overflow it snowed here
Rons Cars
Member - Posts: 16
Posted: March 07, 2003 at 12:01 AM / IP Logged
I went up my steep snowy driveway spinning tires and reving the motor in my manual shift car, I notice some anitifreeze in the snow , it came from the over flow tank, is this common when reving motor, you can email me if you want ronplanes@cs.com
floaterr
Silver - Posts: 383
Posted: March 07, 2003 at 5:51 AM / IP Logged
Please make sure to include what kind of car it was and the model of the alarm installed. Otherwise we'll just be shooting in the dark on the options of the alarm and it's abilities.
themagicone
Silver - Posts: 325
Posted: March 07, 2003 at 10:26 AM / IP Logged
I would say its normal, if your engine gets hoter the normal your coolant expands and if the tank is full the only way to go is out. I wouldnt worry unless you notice it all the time
Haku
Copper - Posts: 204
Posted: March 07, 2003 at 12:06 PM / IP Logged
I would, (short of having it professionaly checked out) first replace the radiator cap, these are a common culprit of your problem, but do not rule out, t-stat sticking closed causing overheat, head gasket failure causing pressure in the system.  Plus many more... Most parts stores have the ability to test your radiator cap, there are cheap, but doesnt hurt to have it checked.
Hak
Siemens Autostart
Rons Cars
Member - Posts: 16
Posted: March 07, 2003 at 6:04 PM / IP Logged
I think this is what happened , because the next day I took the car for a 7 mile ride and the fluid was at the right level in the white overflo, what do ya think
Saturday, December 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
