car alarm upgrade kit wiring info
cecilpeter
Member - Posts: 11
Posted: June 08, 2008 at 2:50 AM / IP Logged
Hi Team,
Iam a new member here at 12Volt.com, I have recently bought a Car Alarm upgrade kit for my Hyundai Accent GLS 2002 which was fitted with a Keyless Entry system a few months back,
The issue that I have is that I need to know where I need to connect these outputs from the Car Alarm Upgrade controller, do I need to connect these outputs parallel to the existing Connections of the Central locking ?
Any diagram or directions  for this issue would be much appreciated.
Regards,
Cecil Peter Vaz.
kola7126
Copper - Posts: 93
Posted: June 08, 2008 at 2:07 PM / IP Logged
 MODEL YEAR(S)
 ACCENT  2001 -2002
 KEY T-HARNESS IMMOBILIZER
  N/A   N/A   N/A
 PART  COLOR LOCATION
 12 VOLT CONSTANT  RED (+)   IGNITION SWITCH HARNESS
 STARTER WHITE (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 GREEN (+) IGNITION SWITCH HARNESS
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 YELLOW (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 BLUE (+)  IGNITION SWITCH HARNESS
 KEYSENSE N/A
 PARKING LIGHTS ( - ) GREEN (-)
 PARKING LIGHTS ( + ) GREEN/ ORANGE (+) and GREEN/ BLACK (+) Use both, See NOTE *2  IN DRIVERS KICK PANEL See DIAGRAM
 POWER LOCK ADD ACTUATOR, See NOTE *1  TO DRIVERS DOOR ONLY, See DIAGRAM
 POWER UNLOCK ADD ACTUATOR, See NOTE *1  TO DRIVERS DOOR ONLY, See DIAGRAM
 DOOR TRIGGER GREEN (-)  IN DRIVERS KICK PANEL
 DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Part #775 Relay
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN BLUE/ORANGE (-)  @ STEERING COLUMN HARNESS
 TACH GRAY  @ ECM, UNDER DRIVERS DASH, PIN 8
 WAIT TO START LIGHT N/A
 BRAKE PINK/BLACK (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  N/A
 ANTI-THEFT N/A
 EXTRA INFORMATION
 NOTE *1 if vehicle is equipped with a FACTORY KEYLESS use the BLACK/ ORANGE (-) for the LOCK and use the YELLOW (-) for the UNLOCK (TYPE B), these wires are found at the ETAC Module located to the LEFT of the STEERING COLUMN. WITHOUT a FACTORY KEYLESS, this vehicle uses a CENTRAL DOOR LOCKING SYSTEM, to add KEYLESS ENTRY to this vehicle, add a #742 Actuator Motor to the DRIVERS DOOR ONLY, See DIAGRAMS. NOTE *2 this vehicle has 2 PARRKING LIGHT wires, that will require 2 extra relays part #775, to connect,
