flex port online
Ravendarat
Platinum - Posts: 2,806
Posted: June 16, 2008 at 2:05 PM / IP Logged
Hey guys, no one around here has flex port for sale and I need some for my newest project. It has to have a inside of 3 inches because of where its gonna go. If anyone has any web sites that has it for sale and can post the link that would be cool. I tried searching and couldnt find it, thanks guys
DYohn
Moderator - Posts: 10,741
Posted: June 16, 2008 at 5:44 PM / IP Logged
What do you mean by "flex port"?  Tubing you can bend or pre-made straight ports with variable length?
Ravendarat
Posted: June 17, 2008 at 4:17 PM / IP Logged
I mean I need a port that I can bend angles in for install as my box is built into the side panels of my truck and since there is not enough room for the port in the box I need to run it from the top and flush it into a panel above the box with it making a couple turns that I cant anticipate the exact angle of ahead of time. I know JL used to make a product such as this but I cant seem to find anything anymore
DYohn
Posted: June 17, 2008 at 4:36 PM / IP Logged
Just use large diameter hose.  Like THIS.  You can put it anywhere you like and simply need to secure the ends to keep it the correct length.  Glue it to a piece of rigid PVC pipe for the exit flange on the baffle.
jmelton86
Gold - Posts: 1,228
Posted: June 17, 2008 at 6:19 PM / IP Logged
DYohn, wouldn't that hose need to be secured throughout the lenth of it? It seems like the air movement would shorten and lenthen the hose as the driver moves back and forth.
It's got to make flapping noises eitherway I would think.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
