prestige alarm/remote starter, 05 magnum
tury
Posted: June 21, 2008 at 6:12 PM / IP Logged
need help with dodge magnum 05 im using a prestige with stater  also im usin a idatalink interface module the problem is the car starts and everyting but each time i use the remote start the check engine light turns on and it dosent come of until i reset the system, alrredy try using voltige and tach mode and the cars starts without any problems but the check engine ligth comes one
if some one can help me i will appreciate thanks
what a car
dtk1
Copper - Posts: 179
Posted: June 21, 2008 at 6:19 PM / IP Logged
chak all your wires make sures they all come on as they should i had this happen to me and my problem was that the second starter wasent time correctly have you try calling idatalink guys ?
tury
Posted: June 21, 2008 at 7:38 PM / IP Logged
no havent but went i use the remote start it start like if i was puting the original key
but theres no specific cable i need to check ore someting or is better if i do the relays for the accesori and the 2nd stater
what a car
tury
Posted: June 21, 2008 at 7:39 PM / IP Logged
or  do you now how to time the second stater
what a car
dtk1
Copper - Posts: 179
Posted: June 21, 2008 at 10:10 PM / IP Logged
if you have acess to relays and resistors try doing it that way take your time and see if problem is solve if it is then the module. the biggest problems with this cars is the MUX wire if you miss a resistor by a % then you would get lights on the dash and codes on the computer. I had one a 300c with the air bag when you starter with the RS and I end up using relays and resistors.
tury
Posted: June 23, 2008 at 12:20 PM / IP Logged
thanks i will try that. ill tell you nif it work thanks again
what a car
