2004 acura tl?
justcolin311
Posted: June 25, 2008 at 9:28 PM / IP Logged
The TL I purchased has the feature to roll up and down the windows and sunroof with the factory keyless entry remotes. The roll down feature works but the roll up wont work with remotes. Can I use a aftermarket keyless system to use these same features without having to buy window up/down modules? Will factory modules work?
chriswallace187
Gold - Posts: 1,661
Posted: June 26, 2008 at 1:30 PM / IP Logged
Can you operate the windows/sunroof via turning the key in the driver's door key cylinder?
If not, you'll need aftermarket modules.
If so, you should be able to use an aftermarket piece to remotely control. The lock and unlock wires from the key cylinder to the driver's door module will need connected to the said aftermarket piece.
I would suggest using something with dedicated auxiliary outputs for the window roll up.
C Renner's Auto Electronix
justcolin311
Posted: June 29, 2008 at 2:46 PM / IP Logged
thanx alot. That will help
Saturday, November 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
