wiring 3 subs to two amps
hookedontronics
Member - Posts: 12
Posted: June 26, 2008 at 10:38 PM / IP Logged
i have (3) JL 13W1v2 subwoofers and (2) e1800d amplifiers that i need wired together/ I really am quite perplexed on how to get it done. I am also running an additional car audio battery. How do i run the 3 subs equally? Diagrams would be prefered but i realize i can not be too picky. thanks
-Jake
If you can't be good, be good at it!
haemphyst
Platinum - Posts: 5,059
Posted: June 27, 2008 at 12:39 AM / IP Logged
You can't. You have single voice coil woofers, and non-strappable amplifiers. The system is mismatched, and incompatible with your desired result.
