autopage keyless.
mdoffroad
Member - Posts: 33
Posted: July 08, 2008 at 8:42 PM / IP Logged
Ok, Its admitedly been more than a few years since I tackled oneof these.....
Autopage Keyless  system KE-120, going into a Chrysler Cirrus with the goofy locking system that requires 2 hotwires, each with differnt values, 620 ohm to unlock and 2700 ohm to lock. Its been TOO long and this thing has onboard relays.... anyone? please, help?
Matt
mdoffroad
Member - Posts: 33
Posted: July 08, 2008 at 10:15 PM / IP Logged
Sorry,it's a 2000 Cirrus, someone, anyone? help?
Matt
Platinum - Posts: 13,726
Posted: July 08, 2008 at 10:28 PM / IP Logged
Here You Go
This shows only a single wire for both lock and unlock. I think the wire needs to be grounded through the resistors for the appropriate function. Hopefully somebody a little more familiar with alarms can confirm this.
mdoffroad
Member - Posts: 33
Posted: July 08, 2008 at 10:31 PM / IP Logged
Lol, I got that part, but I think I also got teh alarm figured, teh diagram wasnt the clearest, but I THINK I got it.... I havent read a wiring schmatic in almost 4 or 5 years.... sad, I know....
Matt
smcshark
Member - Posts: 34
Posted: July 09, 2008 at 9:35 AM / IP Logged
you should first determine if the car has factory alarm or not. It will determine if it is (GREEN/ orange w/450ohm & 850ohm) or White / lt green with the values you have already.
Automotive Electronic Specialist
mdoffroad
Member - Posts: 33
Posted: July 09, 2008 at 4:31 PM / IP Logged
I pulled the build sheet and didn't see keyless entry or factory alarm on the sheet anywhere. I think I found my own answer though. I posted that when my brain was fried.... basically need both door relays powered by a hot wire and they both go to the same wire, one with one resistance,one with the other.... I need ot do that, wire the parking lights and a relay for a truck release and I'm set :)
Matt
