volts, charging system
theterminator
Copper - Posts: 96
Posted: July 13, 2008 at 1:54 PM / IP Logged
Im currently running a Kinetik HC800 as the primary battery. I have also upgraded the Big 3. My car volts sit at 13.1 volts when off. And 14V when on. With the radio turned all the way up the lowest reading i get is 12.4V. So my question is would you consider my cars charging system sufficient enough to run my amp without running the risk of it burning my amp up? Do you think adding another HC800 would help stiffen my volts?
still_walkin
Silver - Posts: 644
Posted: July 19, 2008 at 8:50 AM / IP Logged
you can but but that will put a starin on your alternator to charge both batteries do you have a stock alt. or and upgraded one
1993 sdv
Alpine 4x6 6x9 5 1/4 swr-10d4
alpine v60
12.5 VGA flip down
Nettop pc w/10" touch screen
78nova
5-re audio 5x7 ,10" sub &
Xtx-500.5
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
