02 lexus is300
TheDouche
Copper - Posts: 93
Posted: July 31, 2008 at 8:46 PM / IP Logged
ok so my buddy has a IS300 with premium sound(RDS radio). he was asking if i could help him out with the headunit install. of course i said why not. only problem is ive only really done domestic cars and trucks which are way easy. plus there is sooooo much after market doodie on this IS300 that its not funny(most of it is alarm bull). my question is this he wants to keep the factory speakers(cause they sound nice) but he wants to change the headunit and add a sub(not hard cause ill have rcas then) only prob with this whole thing is how do i go about wiring all this? should i just run all new speaker wire to the speakers and if so how do i keep the factory tweeters? is there a cross over i can buy or make or something to keep all the speakers working correctly?
TheDouche
Copper - Posts: 93
Posted: August 03, 2008 at 8:10 PM / IP Logged
nobody can help me out with a lexus? or did i bite off more then i can chew?
kgerry
Platinum - Posts: 3,455
Posted: August 08, 2008 at 5:49 PM / IP Logged
most Lexuses (Lexi?) i've done you just use an amp integration harness (Metra 70-8112, 70-8113, etc ) to replace the HU and then wire up the sub and sub amp like normal.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
TheDouche
Copper - Posts: 93
Posted: August 08, 2008 at 6:29 PM / IP Logged
they have in amp integration harness? I was told by someone else to get metra tyto01 harness and use that. Will that work? Or is your amp integration harness number universal?
megaman
Copper - Posts: 385
Posted: August 08, 2008 at 6:40 PM / IP Logged
The Metra TYTO-01 harness is designed for Toyota JBL systems.  The Lexus has the Bose which requires s different type of interface.
kgerry
Posted: August 09, 2008 at 1:00 PM / IP Logged
go to Metra's website and look up the vehicle... it will give you a list of all parts available for it... harnesses, kits, etc.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
