viper 550esp remote learning
bigbass007
Posted: August 01, 2008 at 2:47 PM / IP Logged
I've installed a Viper 550ESP without any problems.
Everything works as it is supposed to.
The alarm only came with 1 remote so I purchased a second remote but I'm having a problem programming the new remote.
I can't get the system to go into the learn mode.
All the other programing function work,the valet button works fine.
I followed the instructions to the letter but can't get a chirp.
Door open, key on, press valet button 8x and hold on the 9th to program the new remote all at once but it will not chirp.
Is there a setting on the brain that will not allow a new remote to be programmed?
What am I missing?
Rob
moonliter
Copper - Posts: 322
Posted: August 01, 2008 at 3:32 PM / IP Logged
When adding a new remote, you have to program channel five first for standard configuration. Once you have done that then you can program channel 8 (auto learn )
Mark Mizenko
Copper - Posts: 460
Posted: August 01, 2008 at 3:37 PM / IP Logged
I dont think there was a  Bitwriter option to "LOCK remote programming", but I'm not positive. DOUBLE CHECK the system sees the door open and that the ignition is on.  Make sure you have a good valet switch.  There is a RED switch port, thats for the VRS, you want the BLUE port I beleive.
bigbass007
Posted: August 01, 2008 at 4:08 PM / IP Logged
"When adding a new remote, you have to program channel five first for standard configuration. Once you have done that then you can program channel 8 (auto learn )"
I can't program any channel , that's the problem the brain won't let me into the learning mode.
"I dont think there was a Bitwriter option to "LOCK remote programming", but I'm not positive. DOUBLE CHECK the system sees the door open and that the ignition is on. Make sure you have a good valet switch. There is a RED switch port, thats for the VRS, you want the BLUE port I beleive."
I'm plugged into the blue port,It sees the open door and the ignition being on. The valet works for any other use except letting me into the learning mode.
bigbass007
Posted: August 01, 2008 at 8:30 PM / IP Logged
I decided to pull the fuses in hopes of it resetting itself...after about 30min I reinstalled them and now was able to program the remote.
Thanks for all your suggestions...
Rob
