rav 4 transponder
maxcat
Copper - Posts: 211
Posted: September 04, 2008 at 6:36 PM / IP Logged
Hey all, will be working on a 2008, toyota rav 4 shortly. the paperwork says it may or may not have a transponder system. Is there a way (maybe the key) that you can tell before hand if it is so equiped with a transponder. Was hoping to grab a module before the install if needed.
          Thank-you in advance
enice
Silver - Posts: 857
Posted: September 04, 2008 at 7:36 PM / IP Logged
Always have a module and be prepared to use it.  We(our shop) have figured out that you have to look for something under the key cylinder.  It is a black plug .  If plugged in then it has a transponder.  If there is a plug that is loose(not connected to anything) then it does not.
robertsc
Copper - Posts: 337
Posted: September 04, 2008 at 7:51 PM / IP Logged
all canadian vehicles made 2008 plus
are required by law to have a factory immobilizer
so yes it should have one
Mike M2
Platinum - Posts: 2,652
Posted: September 05, 2008 at 6:33 AM / IP Logged
If there is a security light next to the heater controls it has it. If not, then not. I'd say i see about 60% with....
Mike M2
Tech Manager
CS Dealer Services
Chris Luongo
Platinum - Posts: 3,746
Posted: September 05, 2008 at 4:34 PM / IP Logged
That's interesting what robertsc said about Canadian models, and I do remember hearing that somewhere too.
For the U.S. RAV4, only the Limited trimline, with automatic climate controls, has the immobilizer key.
Base U.S. RAV4s (with three-knob manual climate control) do not have an immobilizer.
robertsc
Copper - Posts: 337
Posted: September 05, 2008 at 7:10 PM / IP Logged
9. IMMOBILIZERS
Every passenger vehicle, multipurpose passenger vehicle, truck and 3 wheeled vehicle manufactured after September 1, 2007 and with a Gross Vehicle Weight Rating (GVWR) less than 4,536 kg (10,000 lbs), except an emergency vehicle or a walk-in van, must be equipped with an immobilization system as per the requirements of CMVSS 114
http://www.tc.gc.ca/roadsafety/importation/VAFUS/list/Explanations.htm
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
