shiva x, mtx thunder 302
cadguy
Posted: September 06, 2008 at 1:30 PM / IP Logged
Hello All,
I've been lurking and trying to absorb as much info from all the posts but I'd appreciate some advice. I recently bought some old amps from a friend: MTX Thunder 302 & an Eclipse 3640. Both for $80 btw. I've googled them both.
I have a 97 Ford Ranger w/ ext. Cab w/ a pair of Boston Acoustic 5x7's in the doors i bought back in 97. Stock 5x7's in the rear panels. Head unit is an Alpine CDE9843. The truck has the V6 4.0L in it so i believe the alternator is rated 95A.
I will eventually replace the BA's in the doors but for now I need to replace the stock 5x7's and install a sub in the cab. I've designed and will build a sealed 1.5 cu.ft. enclosure to occupy the space directly behind the drivers seat for a Shiva-X. Need to keep the cab space behind passenger free for storage, etc.
I'm looking for SQ only w/ around $200 for sub & rear 5x7's. I do have my heart set on the Shiva-X unless there's an issue. I have concerns w/ heat (amps under the seats?) & power. Also need advice concerning using crossovers vs. amp built-in filters. I've already learned a great deal from many of you from previous posts and would like to say thanks for sharing. Any suggestion/advice is much appreciated.
cadguy
stevdart
Platinum - Posts: 5,816
Posted: September 06, 2008 at 1:39 PM / IP Logged
Welcome to the forum, cadguy.  Use the active filters provided by your gear.  Select one of the choices of either using amplifier filters or using the deck's filters (I didn't search specs of the gear).  This is not a situation where building passive crossovers will do any good.
Amplifiers are installed under the seat every day.  Space the amp away from surfaces at both bottom and top to allow for best heat dissipation.
cadguy
Posted: September 06, 2008 at 3:01 PM / IP Logged
Thanks stevdart. Will take your advice on using the amp filters. Here's a link to the MTX Thunder 302. Will that push the Shiva sufficiently? Again, I don't care about SPL. Does anyone have any experience with the Shiva in a sealed 1.5cu.ft. box?? If i increase the volume of the box can i assume i will lose some power? I'd really appreciate some opinions on this one.
Couldn't find any official info on the Eclipse but it's 4x60W and reviews say its power is under rated. I'm assuming 4x60W for the front stage will match up w/ the Shiva. Would you agree? Any suggestions for the rear 5x7's?
DYohn
Platinum - Posts: 10,741
Posted: September 06, 2008 at 4:51 PM / IP Logged
The Shiva-X is one of the best deals currently available.  Highly recommended.  I use them.
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
