05 camry v6 remote starter problem
infiniti2007
Copper - Posts: 67
Posted: September 08, 2008 at 7:47 PM / IP Logged
Hi everyone, I have installed the two way alarm/remote start for my 05 camry v6. I have used the KEY-OVERRIDE-SL2 for my remote to bypass the key. I got everything working except when I start the vehicle with the remote starter , it just start and false, then it restart it again. but if I put the key inside the key cylinder then it works fine. Does anyone know what is color code for key sensing for this car. I used black with silver dot at the key cylinder. I also need the color wire for RX ( DATA) and  TX ( DATA)  for this vehicle please. Thanks.
hhh
Mike M2
Platinum - Posts: 2,652
Posted: September 09, 2008 at 7:01 AM / IP Logged
Keysense is blue, code is green and TX is blue / YELLOW. Here's a diagram http://www.idatalink.com/pdf/viewDoc.php?id=386
Go to Toyota2 wiring...
Mike M2
Tech Manager
CS Dealer Services
infiniti2007
Copper - Posts: 67
Posted: September 09, 2008 at 11:08 PM / IP Logged
Thanks alot Mike , the diagram shows very clear. It worked now. Thanks man.
hhh
