mirrior rattle
04nata
Copper - Posts: 358
Posted: September 19, 2008 at 2:07 PM / IP Logged
50/50 chance of posting in the correct forum
My rear view mirror vibrates like a rabbitt with new batteries   mirrior rattle -- posted image.,  my thought is to drill a small hole in the plastic case and fill it with the spray in expanding foam insulation, BUT, I wanted to see if anybody has tried this before and if it worked or ruined the mirror
haemphyst
Platinum - Posts: 5,059
Posted: September 19, 2008 at 2:22 PM / IP Logged
Even if you do that, it's still going to vibrate... The expanding foam doesn't have enough mass to effectively lower the resonant frequency. You need something FAR heavier... Like lead. Kidding, but NOT kidding about the spray-in not being heavy enough.
No matter WHAT you do to it, it's still going to vibe. It HAS to - it is attached to a vibrating panel; the roof or the windshield.
04nata
Copper - Posts: 358
Posted: September 19, 2008 at 2:26 PM / IP Logged
I think I did not explain good enough, I know it will vibrate, but it rattles (mirror within the case), so in that case do you think it would work or will the pressure crack the mirror?
ps: I used lead on the first one and it fell off,,,,,,,,,,,,,,,,,,,,lol....j/k
