audiovox ccs100 62 falcon problem
mitch_c
Posted: September 24, 2008 at 8:37 AM / IP Logged
I've got a 62 Ford Falcon 2DR wagon that I've put a V8 and AOD trans in..  I have no VSS, have installed one of these units before, but running into problems on this one.
1) No engagement -  Tech Support told me to ground the purple wire, I did, it worked as they said (no disengagement). I then  installed a Single Pole Dual Throw relay, as it wouldn't engage.. I've done so, but now it won't disengage..
2) Speed - I tried the magnet kit, but does not seem to be getting signal, so I put it on TACH ONLY setting (aka Manual Trans config), but didn't pull the jumper (didn't know what that would do).  The unit will engage at 1200 RPM (50mph) but nothing more...not able to increase speed...   Could not pulling the jumper be the problem??
Ideally, I'd just like to use the tach signal only as the source for controlling the cruising speed.  I asked Tech Support about this, person said I had to have a manual trans to do this (which made no sense to me, as the unit doesn't know what kind of transmission I have installed)... the person on the line got down right nasty with me when I asked him why tach signal only will only work on a manual trans installation...
Any help would be greatly appreciated, as I have a 1000 mile drive coming up soon.
sparkie
Platinum - Posts: 2,061
Posted: September 24, 2008 at 7:41 PM / IP Logged
First off, the relay is probably wired wrong. If you are using regular taillight bulbs for the stop lamps, check to see if they are all working. The violet wire in the cruise harness must be grounded for the cruise to work. When you depress the brake switch, the wire will get 12 volts and thus lose ground and disengage the cruise. The switched wire on the brake switch should measure at ground because it is wired in series to ground with the stop lamp filaments inline. If you measure the switched brake wire with the ignition OFF, you should get a reading of less than 10 ohms to good ground. If one of the stop light bulbs is burnt out, you will get a higher resistance reading and the cruise won't work. If you decide to wire in a relay, you need to install in such a way that you don't hear it click everytime you apply the brakes (annoying). Wire it as follows: Terminal # 86 to the switched wire from the brake switch that goes to 12 volts when the brakes are applied. Terminal # 85 to ground. Terminal # 87a to ground. Terminal # 30 to the violet wire from the cruise control.
The cruise control must be able to control the speed of the vehicle.
In a manual trans car you can get away with only using the tach wire because when the car is in gear (usually only 4th or 5th) and the engine RPM is a at a certain rate you will be travelling at a certain speed. There is a direct relationship between gear and RPM. Thus if the cruise only cares about controlling the throttle to keep the RPM's the same, then the vehicle speed will remain constant. The fault with this method is that you need to remember that if you change gears and hit resume, your actual vehicle speed will change relative to the RPM's.
In auto trans vehicles it is better to use a VSS signal. This way the cruise will only monitor the actual vehicle speed and adjust the throttle accordingly and it won't matter if the engine RPM's change with gear changes or changes in the torque converter.
Set up the magnet kit so the sensor is only 1/2 inch away from the head of the sensor mounting bolt when it passes by it. Rear wheel drives should only have 1 magnet on the drive shaft. Mount the sensor as close to the output shaft off the back of the trans. Mount it securely so that bumps don't cause it to move. The drive shaft moves up and down so your sensor must be mounted to one side so the 1/2 inch space isn't altered. Usually if you mount the sensor to the body within 8 inches of a universal joint, you should be OK.
Using the VSS method on a auto trans is the way to go. It will make for a much smoother cruise. If you can get it to work correctly, ground the cruise tach wire. The cruise will work better if it only has one input source. If it tries to adjust to both the VSS and tach the cruise behaves a little funny at times and may not be very smooth.
I hope this helps clear things up. Don't be too hard on the tech support guys. Remember all they deal with is one problem after another which can be hard on a guy.
sparky
mitch_c
Posted: September 25, 2008 at 6:37 PM / IP Logged
Thanks Sparky...
Well, the Autiovox fellow gave me bum info on the relay wiring config... I used yours and the relay now works...
Still can't get the unit to engage properly...
Magnet is installed within 7" of the front U-joint..well within the 1' that the install instructions says is the max distance..    Any idea what the output of the magnet pickup should be?  I would unhook the wire and thread it back thru the window and drive it down the road with a multi-meter hooked up if I knew what output to expect...
Process of elimination continues...
Mitch
sparkie
Posted: September 25, 2008 at 7:17 PM / IP Logged
The magnet kit should give a 2,000 PPM signal. Use only one magnet. The sensor for the magnet has a bolt through it. Make sure the head of the bolt is 1/2 inch away from the magnet when it passes by. Have your sensitivity set for medium. If you have changed any DIP switches you must unplug the unit before it will accept any changes. Make sure that you have no slack in the throttle at rest, but not tight enough to increase the idle speed of the engine. Make sure you adjust the linkage when the motor is cold to account for the choke. Use a vacuum source directly off the engine manifold.
sparky
