2008 sentra vss wire
ryanmc
Member - Posts: 30
Posted: September 27, 2008 at 7:44 PM / IP Logged
i cant find the vss wire
Speed Sense VIOLET/RED (AC) IN HARNESS UNDER CENTER CONSOLE
but i only see 2 violet wires neither with red im not sure if this is even the right harness its going to the computer under the center console. i also looked on speedometer cluster plug and none were purple with red. i also have nird-01 which says it gets a vss signal from the radio plug adapter but its not working
ryanmc
Member - Posts: 30
Posted: September 29, 2008 at 8:06 AM / IP Logged
the wire was actually working from the radio plug i had my e-brake wire grounded causing my trouble..
