current, voltage, ampers issue
mikerizzle9
Posted: October 03, 2008 at 6:38 PM / IP Logged
Okay, I'm getting into my first high wattage system, so I'm running into some electrical concerns I haven't had to deal with before.
I'm running a soundstream PCD1000d at 1 ohm at which its rated at 1k watts RMS. I'm still using 4 gauge knukonceptz power and ground wiring from my old system with an 80 amp in-line fuse. My subs are Alpine Type-R 10's each at 500 RMS. I found on another website that 4 gauge should be able to carry 150 amps and it will take about 150 amps to make my 1k watts anyways.
I know for a fact I'm not gonna get that outta my 05 altima stock alternator, and given I haven't blown my fuse yet I'm no where near my 1k watts. What can I do to test the output I'm getting? Anybody have a link to multi-meter usage? I have never dealt with measuring voltage and how it all translates, and how can I find a website which lists alternator amp output for stock cars? Also, what's the advantage of doing the Big 3 if I'm not making enough amps in the first place??
never trust a fart
stevdart
Platinum - Posts: 5,816
Posted: October 03, 2008 at 7:50 PM / IP Logged
Do the big three to get the most power available from the stock alternator.  If you can't get satisfactory results after that, look into obtaining a high output alt.  Read the sticky posted above for more info.  Also read the What is a Proper Ground sticky.  Fuse the power wire to the capacity of the wire; don't fuse it with an expectation of blowing the fuse so you can be satisfied that the system pulled more than 80 amperes to do so.
Put this website in your favorites folder:  www.bcae1.com  There is a tutorial on measuring amplifier output there, among other things you'll want to learn about.  Send for the CD for more detailed explanations than what shows on the site.
mikerizzle9
Posted: October 03, 2008 at 9:35 PM / IP Logged
Thanks for the reply, that website has some REALLY good stuff and I did bookmark it, so thank you... I'm gonna do the Big 3 regardless cuz I will prob expand at some point in the future. I will also get a proper fuse for the 0 gauge, which takes me here:
You made a good point that I shouldn't be waiting for my fuse to pop to satisfy the idea that you need a certain amount of amps traveling to make watts from my amplifier. But am I wrong in assuming that it will take more than the 80 amps my fuse is rated at to make my 1k true watts. Everything seems to point that it will take at least 150 amps however most amplifiers don't have inclusive fuses which total that amount (mine has 3x30). This non-conformity frustrates me.
People claim they are running >1k watts off a stock alternator, when you are luck to find one in a vehicle that pushes more than 120 amps (at least 30 are used for stock electrics anyways). What am I missing? The math just doesn't add up.
Also, I only have 4 gauge inputs for my amplifier ground to + inputs... Does somebody make some type of converter so I can run 0 gauge all the RIGHT up to the amp and then input my 4-gauge? This also doesn't seem to me to help much. Will it make that much a difference to run 0 gauge everywhere and then pinch it off at the amp for the 4 gauge?
never trust a fart
stevdart
Posted: October 03, 2008 at 10:52 PM / IP Logged
You have to realize that most of what you hear from other people, as well as most of the specs that you read, are simply gross exaggerations.  When one has an amplifier that is "rated" at XX watts, that doesn't mean that it puts out that many watts.  Numbers like that are truly meaningless in today's car audio market.  The reality is that in your daily listening you are likely using one to ten watts from the amplifier.  Once you're at ten watts, you can quickly increase the power demand (and likely the subsequent power output) with just the slightest touch of the volume knob.  And the levels of power at a certain point may just make the sound unlistenable, well below the 1000 watt "rating".
Look at it like this:  the speakers you listen to are designed to deliver a certain decibel level with only 1 watt of power applied when listened to at a distance of one meter.  To achieve a noticeable increase in loudness, you have to apply double the power (that's +3 db).  So say you are listening to a speaker whose output is 87 decibels at 1 watt;  at 2 watts the output is 90 db, at 4 watts it's 93 db, 8 watts goes to 96 db, etc.  And there is likely an additional increase in sound level due to the car environment you are listening in ("cabin gain").  So with this you can see that only 8 watts provides a sound level that when listened to for a prolonged period of time would contribute to eardrum damage.  Another good sticky subject.
As you continue the math that I started, you see how quickly power jumps at those highest levels of output;  e.g. 64 watts to 128 to 256 to 512.  And keep in mind there is still just a +3db sound level increase at each of those incremental changes.  The difference between the 500 watts and the next jump to 1000 watts is not worth consideration.  It is just a rating, whether fairly measured or not, that serves to place the amplifier in competition with a field of other amplifiers who are similarly rated.  A much more valuable datum would be manufacturer quality...not power rating.  A clean 50 watts is more valuable than you might think, because a well designed and built amplifier will have the reserve capacity to provide power for the peaks as well.
With all that, it should be a rarity that you could melt an 80 amp fuse while listening to your system.  The fuse is there to provide the necessary safety factor should an accident occur;  it will keep the wire from being used as a conduit for the battery's reserve amperage to be unleashed into the chassis of the vehicle or through whatever other conduits it can find.  The result of this is usually catastrophic.  But the value of the fuse should be whatever the wire is rated for, as a rule.
When "People claim they are running >1k watts off a stock alternator"  you should realize that they are merely using some gear that has a 1k watt rating, not that the gear is actually providing that power level.
The Knukonceptz 4 ga. wire is sufficient for that amplifier.  Use a beefier wire if it will make you happy.   And I have seen wire ga converters like you asked about;  look through some of the supply houses or ask at your local car audio installation shop.  Or simply use a distro block  which will provide outputs for future additions to the system.
mikerizzle9
Posted: October 04, 2008 at 12:07 AM / IP Logged
Okay now we are talking.. I moved from what everybody would call a 600 rms watt to a 1k watt rms jump, however I honestly did not expect much of a jump listening wise at all. I just hoped to prevent any type of amp overload by picking up something with the reserves to prevent a malfunction.
I'm having problems with my amp not sending ANY power at all to my with like 1%-90% power. The amp doesn't power off or go into protection mode, and EVERYTHING is TIGHT, EVERYTHING!! I have never had this problem before, and it is perplexing. I bought a high current amp, and like u said (and I support) the 4 gauge is sufficient for "1k watts RMS". I know you don't like watts being referred to in these terms as it takes ridiculous amounts of watts to increase dB levels by minuscule levels, I understand that.
I don't know what is wrong with my electrical setup though, I have been running the same setup for almost a year and just started seeing problems, even after an updated ground. Here's the cheese:
-4 Gauge Knu Ground and Power
-"1K RMS" soundstream 1K watt class D
-2 Alpine 1042D's (10 in 4ohm DVCs at 1 Ohm, the amp handles it)
-I'm running an LOC off a stock BOSE system for my amp leads, I wonder if that has something to do with it
I know the Big 3 will "help", but if I'm listening to the system even at SMALL levels (like 5-20%) I will still have problem of the amp cutting off the subs like there insufficient current or SOMETHING!! I just can't make sense to upgrade these expensive wires with time when I'm only listening at minimal levels and having these problems. There has to be something else.
never trust a fart
stevdart
Posted: October 04, 2008 at 7:06 AM / IP Logged
Ah hah,  Bose.
KPierson
Platinum - Posts: 3,527
Posted: October 04, 2008 at 9:54 AM / IP Logged
Did I miss something here?
If you arn't blowing an 80A fuse why would you "get a proper fuse for the 0 gauge".  By the recomendations in this thread that would be a 350A fuse.  Fuses are meant for protection and if you arn't pulling over 80A fusing your power wire at value 4x more then that would be a terrible idea.
"Fusing the wire" is a bad idea for 10ga - 4ga but once you get passed that it is a much better idea to fuse for your expected load.  The idea of a fuse is for it to open as quickly as possible in the case of a catostrophic disaster (ie short to ground).  The larger the fuse value the longer it is going to take for the fuse to open.
Take a look at this 32vdc ANL fuse data sheet:  http://www.cooperbussmann.com/library/bifs/2024.PDF
One thing the datasheet won't tell you is that his is a $68 fast acting fuse.  This isn't a $10 cheapy that you will most likely put in your car.  This fuse will naturally react faster and in a more predictable manner then a "cheap" fuse.
Let's assume:
1. You have the 350A fuse
2. Your current system, under stress of "normal" operation can product 600A of instantanious current.
3. Your power wire shorts to ground
When you power wire shorts to ground every amp of available current (600A) flows between your battery through the 350A fuse to ground (they call this crowbarring the battery).  But, because your fuse is so big, according to the data sheet the fuse will take ~10 full seconds to blow.  That means, every electronic component in your '05 Altima will be subjected to the aboslute worst thing you can do to a car.  Chances are you will be replacing your:
1. Battery
2. BCM
3. ECU
4. Gauge cluster
5. IPDM (intelligent power distribution module
6. Any other CAN based module that Nissan loves to use for every little thing
For a 350A fuse to blow in less then 1/2 second (which is still too long in my oppinion) you will need to be able to supply close to 2,000A of current to it!
For a 350A fuse to blow in 0.1 seconds which is where I would be comfortable you will need 3,500A of power!!!!
Again, to summarize - fuses are protective devices to not only protect the wire, but the battery as well.
For smaller systems fusing the power wire is ok (take a look at how much current it takes to blow a 150A fuse in 0.1 seconds - > 1,200A) (An 80A fuse takes about 700A of current to open in 0.1 seconds).  For larger systems it is extremely beneficial to calculate your expected load and fuse accordingly.
The longer your battery is "crowbarred" the higher the chance electronic parts will be fried
Using a large fuse, IF you need a large fuse, is a nessessity.  But, using a large fuse just for the sake of not spending a few mintues calculating your expected load is sloppy and very risky.
Kevin Pierson
stevdart
Posted: October 04, 2008 at 7:38 PM / IP Logged
Mike, if all you changed in your system was the amplifier, then it's the amplifier to blame if that is when trouble began.
megaman
Copper - Posts: 385
Posted: October 04, 2008 at 11:53 PM / IP Logged
Let's assume:
1. Battery
2. BCM
3. ECU
4. Gauge cluster
Correct me if I missed something here, but if you have an 0 gauge power wire with a 350 amp fuse, then if it shorts to ground, the current flows through the 0 gauge until the fuse blows.  Why would the current surge through the entire system?  Your load from the power source would be the 0 gauge.  Yes, I can see that all the electrical systems share the same ground, but with your reasoning, it would happen in all occurances with over current conditions.  If your 20 amp cigarette lighter shorts out, then why doesn't the 5, 7.5, and 10amp circuits blow in the vehicle as well?  If, for some strange reason, the high current demand pulled from every circuit, then the individual fuses would blow to protect the electrical equipment in the vehicle.  It's the same scenario why one shorted circuit doesn't effect other circuits in the system, but just on a grander, more, extreme scale.
KPierson
Posted: October 05, 2008 at 8:51 AM / IP Logged
You are correct the full current would only flow through the fuse, you wouldn't pull that amount of current through every circuit in the car.  But, every device connected to the battery would be effected by the drop in battery voltage and the immediate loss of current to the device.  Every cap in every power supply of every electronic device in the car would backfeed voltage back to the battery, as the battery tries to provide the absolute most amount of current as possible.  This is very hard on car power supplies and the likely hood of them failing would be great, especially if it is an intermittent short to ground - something a 350A fuse would never protect against.
You can't compare a short to ground through a 15A cigarette lighter jack to a 350A short to ground through a 0awg cable.  If you think you can, you missed the entire point of the 10+ second delay for a 350A fuse to blow vs. the 0.001 second (estimate) of a 15A fuse to blow when shorted to ground.
When dealing with any electronic device with a power supply (ie car battery) about the worst thing you can do is short out the power supply (ie car battery).
Kevin Pierson
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
