2008 dodge ram alarm wiring
Welcome Guest :)
acboomer1
Member -
Posted: October 09, 2008 at 7:55 AM / IP Logged
wiring info for 2008 Dodge Ram 1500 Big Horn. car alarm and remote start. extra items needed or to make install easier
ckeeler
Gold -
Posted: October 09, 2008 at 9:09 AM / IP Logged
| RAM FULL SIZE PICKUP | 2007 -2008 |
| KEY | | IMMOBILIZER |
| N/A | N/A | Transponder Anti-theft PK3 + requires bypass module |
| PART | COLOR | LOCATION | |
| 12 VOLT CONSTANT | LIGHT BLUE/RED (+) | IGNITION SWITCH HARNESS | |
| STARTER | YELLOW/GRAY ( NOT FOR REMOTE START ) | IN GRAY PLUG NEAR BATTERY | |
| STARTER 2 | PURPLE / BROWN (-) see note * | | |
| IGNITION 1 | PINK/WHITE (+) | IGNITION SWITCH HARNESS | |
| IGNITION 2 | N/A | N/A | |
| IGNITION 3 | N/A | N/A | |
| ACCESSORY /HEATER BLOWER 1 | PURPLE / BROWN (-) see note * | | |
| ACCESSORY /HEATER BLOWER 2 | N/A | N/A | |
| KEYSENSE | N/A | N/A | |
| PARKING LIGHTS ( - ) | N/A | N/A | |
| PARKING LIGHTS ( + ) | WHITE/ YELLOW AND WHITE/ GRAY | LOW IN DRIVERS KICK PANEL | |
| POWER LOCK | PURPLE / DARK GREEN (-) SEE DIAGRAM | REQUIRES 820 OHM RESISTOR | |
| POWER UNLOCK | SAME AS LOCK WIRE | REQUIRES 330 OHM RESISTOR | |
| LOCK MOTOR WIRE | LIGHT GREEN | IN DRIVERS KICK PANEL | |
| DOOR TRIGGER | SEE NOTE ** | LARGE GRAY PLUG IN KICK PANELS | |
| DOMELIGHT SUPERVISION | YELLOW/LIGHTBLUE ( + ) | IN DRIVERS A PILLAR | |
| TRUNK RELEASE | N/A | N/A | |
| SLIDING POWER DOOR | N/A | N/A | |
| HORN | DARKGREEN/ PURPLE (-) | IN STEERING COLUMN HARNESS | |
| TACH | DARKBLUE/GRAY SEE NOTE *** | AT PCM | |
| WAIT TO START LIGHT | N/A | N/A | |
| BRAKE | WHITE/ TAN (+) | AT SWITCH ABOVE BRAKE PEDAL | |
| FACTORY ALARM DISARM | DISARMS WITH FACTORY REMOTE ONLY | N/A | |
| ANTI-THEFT | TRANSPONDER ANTI-THEFT | AT IGNITION TUMBLER | |
| NOTES |
| NOTE * THIS VEHICLE HAS A SPECIAL IGNITION THAT REQUIRES A BYPASS MODULE. THE MODEL NUMBER OF THE MODULE WOULD BE A PKUCH2GX. THIS MODULE TAKES CARE OF THE IGNITION AND ANTI-THEFT IN VEHICLE.NOTE ** THE LEFT FRONT DOOR IS PURPLE IN PIN 1. THE RIGHT FRONT DOOR IS PURPLE / WHITE IN PIN 4. THE LEFT REAR DOOR IS PURPLE / ORANGE OR PURPLE /GRAY IN PIN 2. THE REAR DOOR IS PURPLE / YELLOW OR TAN / YELLOW IN PIN 3. USE ALL 4 WIRES AND DIODE ISOLATE EACH WIRE FROM EACH OTHER AND THE INSTRUMENT CLUSTER.NOTE*** THE PCM IS ON THE PASSENGER SIDE FIRE WALL . |
acboomer1
Member -
Posted: October 09, 2008 at 9:34 AM / IP Logged
Thanks, should be a smooth transistion
Monday, February 16, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
